AFM after intercooler ??st185
Postby partsmax » Thu Feb 28, 2013 5:00 am
i am interesting of relocated my afm after the intercooler in my st185 ; i saw afm in intercooler pipe in some mazda and run fine
has anyone tried this?
and what are the benefit and problems in this setup?
sorry for my english im from latin america panama
______________________
celica gt-four st185
panama, panama city, central america
partsmax
Re: AFM after intercooler ??st185
Postby UtahSleeper » Thu Feb 28, 2013 5:35 am
I think there are too main issues. One, our AFM SUCKS!!! Two, the size of it makes locations limited, plus you would have to extend the wiring. Why do you want to do this?
UtahSleeper
Postby 4rsnduction » Thu Feb 28, 2013 7:41 am
The AFM body is also home to the IAT sensor and that thing likes to see fresh cool air not hot compressed air.
Post turbo is ludicrous....That's not what it was designed for, that's not how it works.
4rsnduction
Postby brutekiller787 » Thu Feb 28, 2013 3:30 pm
And you didnt read because he said post intercooler. I think rather than anything, it would not be designed to be leak proof from front to back. It is not design for pressure to go through it.
brutekiller787
Postby yoshimitsuspeed » Sat Mar 23, 2013 11:05 pm
Your AFM measures volume of air. After the turbo volume is reduced as pressure is increased. Put your AFM anywhere after the turbo and it will measure much less air passing through it causing the car to run very lean. If the car was designed to run that way it would work. If someone had aftermarket engine management or was able to tweak the system while monitoring things like AFRs it has been made to work but there is really no good reason to try. Without the right tools to monitor everything it would just be very dangerous.
yoshimitsuspeed
Postby underscore » Sat Mar 23, 2013 11:52 pm
It could probably be made to work, but I'm not sure why anyone would do that.
Postby RedCelicaTRD » Sun Mar 24, 2013 3:36 am
It's been done before. Don't remember it working much better then the stock setup.
Postby Meurz » Sun Mar 24, 2013 11:42 am
HKS pushed 400 ps through it back in the day. Quick phone pic from Hyper Rev 30:
Turbocelica.nl
Meurz
Postby Mafix » Tue Mar 26, 2013 6:44 pm
it is far more common on mercs and porsche back in the day. the issue is the mapping in the stock ecu will be very very wrong. so you'd need an interceptor or standalone. at that point you shouldn't need the afm.
Postby zero06 » Sat Apr 27, 2013 7:51 pm
you would not want to do this. you would have massive pressure drop and a big loss of power.
zero06
Postby 4rsnduction » Sat Apr 27, 2013 11:28 pm
Meurz wrote:HKS pushed 400 ps through it back in the day.
HKS also had an additional unit similar to a powerFC that could help improve what the ECU saw as far as signals go
4rsnduction
Users browsing this forum: Google Adsense [Bot] and 3 guests
