st205 swap
st205 swap
Postby quieter » Thu Mar 14, 2013 12:29 am
hi guys! so im about to swap from a 2nd gen to a 3rd gen. i was wondering what was the outder diameter of the stock BOV mounting point on the WTA intercooler so i know wich coupler to buy for a hks ssqv . The swap comes from japan so i was also wondering what would i need to take off the top speed cut? is it with a resistance? anything else i should know before doing the swap other than polyfilling the engine mounts and getting brass shifter bushings? i already got a brand new clutch, presure plate and an 11 pound flywheel . also got the 3 inch downpipe and exhaust manifold. also did a battery relocation, cant wait for no MAF! lol. im also interested in buying a standalone but im going to save up 1-2k first because the swap alone is going to cost alot. my st205 transmission blew so this is the reason why im upgrading. thanks!
2011 BMW 535xi M pack (daily)
-Simon
quieter
Re: st205 swap
Postby phattyduck » Thu Mar 14, 2013 6:23 pm
ST165/ST185 exhaust manifolds will not bold on to the ST205 head. You should stick with the stock exhaust manifold anyway.
Other mods/etc. are up to you. Make sure you get a clip so you can get all the wiring (if you are going with the 3rd gen electronics). Some of important wiring goes through the fender/core support for the intercooler system...
Top speed cut is at 180kph/112mph. I use a rev-speed meter on mine to get rid of it. You will need to keep some speedo signal going to the ECU, and it takes more than a simple resistor to change the signal.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Re: st205 swap
Postby quieter » Thu Mar 14, 2013 7:16 pm
are you saying his because the exhaust manifolds for 1st and 2nd gen 3sgte have 7 bolts? because i got 9 and it still fits on my 2nd gen,. it should be fine on the 3rd gen with the ct20b. im probably going to use my speedometer cable and not go electronic.
-Simon
quieter
Re: st205 swap
Postby 83841 » Thu Mar 14, 2013 7:22 pm
What exhaust manifold are you running?
-1977 Celica GT (white) Sold
-1980 Celica Coupe (Brown) Sold
-2000 Celica GT-S (Black) Sold
-1993 MR2 (Teal) Sold
-2007 FJ Cruiser (Black) Sold
-2006 Evo IX MR (Grey) - Garaged
-2008 S2000 (Silver) - daily
-1994 Celica GT-FOUR - WRC (Silver) - Garaged
83841
Re: st205 swap
Postby quieter » Thu Mar 14, 2013 7:25 pm
some aftermarket one off ebay with 9 bolts
-Simon
quieter
Re: st205 swap
Postby 83841 » Thu Mar 14, 2013 7:37 pm
I read on GT4OC that the stock ST205 exhaust manifold can take a beating....and alot of em are using stock. I was looking for something aftermarketish so i can try to squeeze out more powah... Stock exhaust manifold should suffice.
83841
Re: st205 swap
Postby underscore » Thu Mar 14, 2013 7:40 pm
Yeah the stock manifold is supposed to be good to 500HP or something near there.
Re: st205 swap
Postby quieter » Thu Mar 14, 2013 7:45 pm
thanks for the info! i still wonder whats the diameter of the WTA intercooler entry for the BOV. id like to take off the stock piping to make more space in my engine bay. i want to see what type of flange i would have to buy.
-Simon
quieter
Re: st205 swap
Postby 83841 » Thu Mar 14, 2013 7:48 pm
Ill measure it for you when i get home....
83841
Re: st205 swap
Postby quieter » Thu Mar 14, 2013 7:50 pm
thanks man! i also found a way to take the speed limit off the JDM ecu viewtopic.php?f=49&t=35240
nvm its for st185 ecu only.
i wonder if theres another way other than the rev speed limiter. im probably going to get a standalone but wtv i think i can wait
-Simon
quieter
Re: st205 swap
Postby 83841 » Thu Mar 14, 2013 8:07 pm
HKS SLD ( speed limit defencer defender )
http://www.rhdjapan.com/hks-sld-speed-l ... ype-i-9835
Found this on GT4OC for you if your running stock JDM ST205 ECU
ECU will have 3 plugs. What you need are:
Big Brown Wire (Earth)
Black/Yellow Wire (12 Ignition Power)
Orange Wire (Speed Signal to ECU)
Check an ECU pinout diagram if you're not too sure where those are but they're all unique from what I can remember and pretty easy to find imo.
Make sure you have a decent set of crimps or needle nose pliers as the bullet crimps supplied aren't the best for the size of wire you'll be crimping, ended up soldering mine.
Black Wire on SLD -> Brown Wire
Red Wire on SLD -> Black-Yellow Wire
White Wire on SLD -> Orange Wire Loom Side
Yellow Wire on SLD -> Orange Wire ECU Side
There may also be a blue wire on the SLD but this is not used from what I can tell. Instructions are only guaranteed for ST205's and not other GT4s as I can't honestly say everything will be the same, I would imagine they are but without having wired one up in one I can't say for certain. SLD also tucks away nicely under the little L-Bracket thing under the ECU that the carpet velcro's onto. Works a treat as far as I can tell. Hopefully this information will help someone.
83841
Re: st205 swap
Postby 83841 » Thu Mar 14, 2013 11:04 pm
The hole where the stock BOV is installed at is
inside diameter = 1"
outside diameter = 1 3/16"
Hope that helps.
83841
Re: st205 swap
Postby quieter » Fri Mar 15, 2013 2:30 am
thank you so much man! you were really helpful
-Simon
quieter
Re: st205 swap
Postby phattyduck » Fri Mar 15, 2013 4:03 pm
quieter wrote:are you saying his because the exhaust manifolds for 1st and 2nd gen 3sgte have 7 bolts? because i got 9 and it still fits on my 2nd gen,. it should be fine on the 3rd gen with the ct20b. im probably going to use my speedometer cable and not go electronic.
ST205 motors have 9 studs like the late ST185's, but the exhaust ports are different size shape and location. The stock manifold is good to 500-ish HP (and isn't a restriction). Just use the stock manifold.
phattyduck
