ST 165 Engine tear down
Postby JohnNK » Fri Mar 15, 2013 8:06 pm
Greetings,
Just picked up a spare long-block for my ST65. I am beginning the tear down process. What size bolt is used to rotate the crank? Any other advice would be greatly appreciated.
Thanks!
JohnNK
Re: ST 165 Engine tear down
Postby Rpz123isme » Fri Mar 15, 2013 9:07 pm
JohnNK wrote:Greetings,
Thanks!
I dont like using a bolt. I get a large open end adjustable wrench and turn the crank against the pulley key. It minimises thread and bolt problems. It also allows you to turn the crank both clockwise and counter.
Hesperia, CA
Rpz123isme
Postby JohnNK » Mon Mar 18, 2013 4:48 pm
Thanks for the advice. I will give that a shot.
JohnNK
Postby gearhead313 » Mon Mar 18, 2013 9:24 pm
17mm or 19? Just crank the bolt in there and turn it. I've done that for years with no issues.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Users browsing this forum: Yahoo [Bot] and 3 guests
