Rear brake help
Rear brake help
Postby mkchris89 » Sat Mar 30, 2013 2:58 pm
So just did the rotor and pads on my rear end test drove it about 4 to 5 miles figured out i had a stuck slide pin lubed it up fixed. Now have a wavy grinding sound could I have Warped the rotor in 5 miles? Or I also found that my hand brake has the half inch spring with cap that holds the shoe to the inside of the car is gone and the shoe is sitting angled to the outside of the car could that be my grinding?
I did take a grinder to part of the shoe that I thought looked like it was touching the rotor slapped it all back together and still making wavy grinding sound so im going to go take it apart again to have a look ill take some pics in case anyone wants to see what im talking about.
Long shot, I might just have to buy a hand brake assembly kit because it needs it and go ahead and turn the rotor see if that does it but any advice is welcomed
edit - I thought i was in handling and braking forum sorry can a mod move this?
mkchris89
Re: Rear brake help
Postby Awesome-Trac » Sat Mar 30, 2013 4:32 pm
Funny I have the same problem on my GTS after changing my rotors to sloted/cross drilled with new pads, it started making a weird noise as well like its consistly grinding on something so I changed it back to stock and it went away.
•Daniel
Awesome-Trac
Re: Rear brake help
Postby mkchris89 » Sat Mar 30, 2013 6:16 pm
Yeah im almost positive its the hand brake still just because the spring that should be there isnt lol so ill probably just get a handbrake rebuild kit.
I just think its funny with the old rotor it didnt do this but maybe the old owner neglected it and it wore it down far enough not to touch.
mkchris89
Re: Rear brake help
Postby Meenya » Tue Apr 02, 2013 12:37 am
I bought a kit recently from Napa that came with all the springs and adjusters, don't have the part handy but I'm sure if you give them make, year and model they will find it for you.
Mike
93 Turbo 4WD
91 GTFour RC
07 R6
Meenya
Images: 19
Re: Rear brake help
Postby gearhead313 » Tue Apr 02, 2013 10:06 pm
Take the e-brake out of the equation. It should be fine even if the pad isnt held by that spring thing. The caliper should push the pads to the rotor and thats it. The rotors wont warp after a few miles unless the brakes are hanging up and getting super hot, which definitely check! Sometimes if the e-brake lever is actuated, it wont let the pads return fully after the brakes are released.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Re: Rear brake help
Postby brutekiller787 » Tue Apr 02, 2013 10:59 pm
Pads on the ebrake? We have drum in hat, shoes for the e brake, pads for the foot brake. It is possible if the ebrake shoe was cocked in it's bracket, or lug nuts were improperly torqued, that the rotor could warp, causing a "wavy grinding noise.
E Brake appliction does not move the pads in the rear caliper though.
brutekiller787
Re: Rear brake help
Postby underscore » Tue Apr 02, 2013 11:30 pm
mkchris89 wrote:Yeah im almost positive its the hand brake still just because the spring that should be there isnt lol so ill probably just get a handbrake rebuild kit.
If you're missing the handbrake springs it's likely rubbing the rotor. My shoes budge out quite a bit with the stupid spring missing.
Re: Rear brake help
Postby mkchris89 » Wed Apr 03, 2013 11:00 am
That's what I'm thinking really only thing that makes sense. I'll have to get one of those kits plus if nothing else it needed to be done
mkchris89
Re: Rear brake help
Postby gearhead313 » Thu Apr 04, 2013 10:48 am
ahh i was thinking of something else! :oops:
true, if theres no spring holding the shoes back, then ?
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
gearhead313
Re: Rear brake help
Postby mkchris89 » Fri Apr 05, 2013 3:28 pm
4 hold down springs $10, 4 pins $10, and 8 hold down cup $20, never have to rebuild the damn hand brake ever again PRICELESS :lol: (I hope)
god I love these cars :bangshead: lol
mkchris89
Re: Rear brake help
Postby underscore » Fri Apr 05, 2013 4:10 pm
I probably should have bought everything new but that can wait til next year. Alternately at least the pins for those springs were used in a lot of other cars, but digging them out at the wreckers would be a pain.
Re: Rear brake help
Postby mkchris89 » Sat Apr 06, 2013 12:47 pm
yeah I figured might as well just get new but hope autozone has the shoes for cheaper then stealership I think the price was like 40 bucks per shoe something crazzzyyy!
mkchris89
