Stock ecu not programmable from dyno ?
Postby celigts » Mon Apr 22, 2013 12:27 am
If I was to have my car dyno'd would there program be able to tune it on site from the stock rom unit or no? Didn't think so but asking anyways.
Otherwise is it worth it to get it reprogrammed by ats?
How about st205 ecu's?
3SGTE project motor very slow
celigts
Re: Stock ecu not programmable from dyno ?
Postby UtahSleeper » Mon Apr 22, 2013 4:51 pm
I dont believe the stock one's are programmable. Could piggy back it or maybe just get a stand alone?
UtahSleeper
Postby celigts » Mon Apr 22, 2013 5:32 pm
Stand alones are alot :/ piggyback I'm finding is the option to go. Was priced at $999 from ats for the stock ecu reprogram.
celigts
Postby polm » Mon Apr 22, 2013 8:07 pm
For less than 999$ you can have a megasquirt-II installed and tuned...Just saying.
polm
Postby l0ch0w » Mon Apr 22, 2013 9:24 pm
Figure this... The stock ECU has a hardware flashed ROM. Its a very early and very crudely programmed ECU. Heck its still OBD I. If you wanted to flash the stock ECU, you would need to un-solder the rom chip, put it into a reflashing machine, know how all the code talks to itself, and manually update all of the fueling tables. I believe that ATS racing down in Texas has been able to see the code on the factory ECU, but its still unknown what everything does. Look around, see if you can find a PowerFC or a megasquirt for cheap. Only issue with MS is that you probably will have to do all the tuning yourself. There arent exactly people out there who are paid to tune megasquirt...
Andrew
1991 Red Alltrac
l0ch0w
Postby underscore » Mon Apr 22, 2013 11:41 pm
I don't think any car has a tuneable stock ECU, you're best bet if you have issues with the stock setup would be to go to a standalone, IIRC piggybacks can only make very minor tweaks due to how our system works.
Postby UtahSleeper » Tue Apr 23, 2013 12:50 am
I know there is more cost then this for going standalone, but compare this to 999
http://www.diyautotune.com/catalog/megasquirtiii-ems-system-with-ms3x-expansion-v357-assembled-p-435.html
MS3 has alot of IO and knock sensor crap, plus no more MAF
UtahSleeper
Postby Tecker185 » Tue Apr 23, 2013 1:18 am
I've got the aem ems-4 I've got like $850 in it running.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Postby brutekiller787 » Tue Apr 23, 2013 5:24 am
thats about the cost of mspnp for st185s
brutekiller787
Postby Tecker185 » Tue Apr 23, 2013 12:52 pm
Yeah but there's aem tuners everywhere.
89 ST165
89 SV25
86 AE86 1uz swap
89 AE95 sedan
Tecker185
Postby l0ch0w » Tue Apr 23, 2013 12:57 pm
Most honduhs and subarus can have a rom tune done with special and cheaply available equipment. They just plug into the OBDII port and tune away, its literally as simple as that.
Andrew
1991 Red Alltrac
l0ch0w
Postby UtahSleeper » Tue Apr 23, 2013 2:23 pm
The reason I think the MS3 is worth a look is with all the IO. I have looked into the AEM-EMS4 and the MS3 had more potential for expansion, which It hink is a good thing to keep in mind, but available tuners is something to keep in mind also.
UtahSleeper
Postby MWP » Tue Apr 23, 2013 2:51 pm
underscore wrote:I don't think any car has a tuneable stock ECU
:shoots:
*lots* do.
Postby underscore » Tue Apr 23, 2013 5:29 pm
Interesting, I always thought they required some kind of piggyback system to be added to the ECU.
Postby Bobbyx661 » Wed Apr 24, 2013 4:56 am
so i have an apexi AVC-R,and some people were telling me i can somewhat tune the car through that. is that true?? they are mostly honda boys lol so id rather ask you guys!
Bobbyx661
Images: 8
