Block tear down
Block tear down
Postby JohnNK » Sat May 11, 2013 3:54 am
I am about to disassemble the bottom end of an ST 165 engine. Is there an order to remove the rods from the crankshaft?
JohnNK
Re: Block tear down
Postby celicast184 » Sat May 11, 2013 1:45 pm
no... jus make sure u cover the rod bolts with rubber tubing to prevent them scratching the cylinder walls as they are coming out.
I <3 MY ST214
celicast184
Re: Block tear down
Postby JohnNK » Sun May 12, 2013 5:28 am
Thanks. Good advice.
JohnNK
