Auto/5 speed spacer/block off plate interchangable?
Postby celica-fiend » Sun Jul 14, 2013 5:55 pm
Swapping a ST185 trans into my previously auto Camry Alltrac.. occurred to me I may be missing a piece..
Does the attached picture look the same as the 5 speed blockoff plate or do I need to source one?
thanks,
Brett
celica-fiend
Re: Auto/5 speed spacer/block off plate interchangable?
Postby phattyduck » Mon Jul 15, 2013 8:12 pm
Those covers should work just fine. They are both more engine related than transmission related (i.e., the ST205 lower cover plate is integrated into the aluminum oil pan, etc.)
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
