CT26 compressor wheel upgrade worthwhile?
Postby knowitalls » Tue Aug 06, 2013 2:41 am
I have been doing a ton of research lately about the CT26 and its upgrade potential but have yet to come across someone who has done it themselves. Its always "a friend of a friend said it was awesome!", or theory.
Have any of you upgraded your CT26 with a bigger compressor wheel (i.e. 16g, t04e, 60-1) and/or done the 10-12 degree exhaust wheel clip? What were the results? Anyone have dyno sheets of before and after?
Is it better just to replace the CT26 with an entirely different, larger turbocharger now that they are coming down in price?
Thankyou
If you didn't build it, it ain't yours.
knowitalls
Re: CT26 compressor wheel upgrade worthwhile?
Postby brutekiller787 » Tue Aug 06, 2013 3:54 am
Pretty much not worth it when gt28rs's can be had for about what a ct26 upgrade cost. Dual ball bearing vs journal bearing? Not much to be though about there. If you are shooting for over 300whp, which most of us do, then a ct26 upgrade is out of the question
brutekiller787
Postby knowitalls » Thu Aug 08, 2013 6:18 pm
Thank you for the response. Now the question is, GT28r or GT30r? What amount of HP is fun for the street? I guess I have some more research to do on what people are running and how they feel about their particular setup.
knowitalls
Postby warracer » Thu Aug 08, 2013 7:18 pm
just pointing out one little detail, if you're on a budget, the CT26 upgrade could be the solution but honestly, I would just go with a CT20B if you're considering that option .
Because if you upgrade you're turbo to a completly different housing, lots of custom fab and work will be needed, oil line , coolant line, intake, downpipe , exhaust , injectors, Standalone or something else etc etc etc
If you want the most cost effective turbo upgrade, ct20b is probably the easiest way to do it, it is bolt on without any sort of modification...
I installed a VF28 which is a Ver.5 STI turbo ball bearing etc etc... And let me tell you that the suprise cost are considerable when fitting a custom turbo setup...
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby zero06 » Sat Aug 10, 2013 8:15 pm
advice from my personal experience... if you mess with any oem turbo, pushing it past what it was engineered to do, an aftermarket wastegate actuator is a must. Also port the internal wastegate for good measure. There is no downside, and you will save a lot of time and frustation. all that aside I had a ct27 and was quite happy with it, more so than the ct20b. boost came on faster pulled harder and lasted till redline.
zero06
Postby lumbercis » Sun Aug 11, 2013 2:06 am
I think the only worthwhile CT26 upgrade is an ATS CT27 or replacing the turbo with a CT20B. Most of the random wheel upgrades for CT26's are untested hackjobs.
Caldina powered...
lumbercis
Postby celica_gtx » Tue Oct 29, 2013 6:24 pm
I went thro these guys. Paid 200 for it all plus a ceramic coating. And I'm happy w it
http://turbocharged.com/main.htm
larger t04e compressor wheel of your choice (we recommend t04e 50 trim)Upgrades also include machining the compressor housing and bearing housing to accept the larger compressor wheel.We install larger 360 thrust bearing and stagger gap turbine side seal." said by tje shop
Pics r in my build. Havent turn the boost up on it yet tho
viewtopic.php?f=44&t=45039
transformation has BEGUN!!!
90GT W/ 90 3SGTE/ SOLD
91 ALL-TRAC 215 w 205 swapd
10 Scion Xb-kid hauler
celica_gtx
Postby Chuck.hudson » Tue Oct 29, 2013 11:26 pm
So what exactly did this company for 200 bucks cause that seems way to good to be true have you ran the turbo yet? I looked at the website now I'm no web designer but it looks like something you would make in a high school computer class
Chuck.hudson
Postby celica_gtx » Wed Oct 30, 2013 5:09 am
Sry forgot to mention I gave em a spare core I had that was toast yea the site is weak but the shop is turbo heaven!!!! Had a chubby the whole time! :smokes: Lol give em a call
Also cash deals usually help too..
Turbo is on my car as we speak set a stock psi waitin to get my apexi avcr fixed
celica_gtx
Postby Rick89GTS » Wed Oct 30, 2013 3:17 pm
Chuck.hudson wrote:So what exactly did this company for 200 bucks cause that seems way to good to be true....
I'd like to know too :)
Rick89GTS
Postby celica_gtx » Thu Oct 31, 2013 4:35 am
Read above ur post...a burnt ct26 n cash.. its a mah n pah shop call em up see what the quote u.
I'm just tellin u what I got. I said the same thing when he said the price n I wasnt gunna say no charge me more..lol
celica_gtx
Postby Rick89GTS » Thu Oct 31, 2013 5:15 am
^I read that but was shocked - I thought there was more to it. Killa deal man :shock:
Rick89GTS
Postby gt4gordon » Thu Oct 31, 2013 6:10 am
I had a ct26 rebuilt to stage 2 from turbo force a few years ago. made a massive difference. cost me £900 uk. I had a st185 with st205 engine. front mount , walbro fuel pump, custom ic piping, low mount air filter, turbo back tte exhaust system exedy twin plate clutch and light weight flywheel. it was rolling roaded at 326bhp and 299lb/ft at 0.9 bar.
gt4gordon
Postby knowitalls » Sat Nov 02, 2013 1:08 am
Ugh, I hate conflicting responses but I think I will give that shop a call and see what they quote me.
knowitalls
Postby Chuck.hudson » Sat Nov 02, 2013 12:48 pm
Well I checked the website ago in two days ago and it was down and I also called but they didn't answer so let us know if you get through and what they say
Chuck.hudson
