CT26 compressor wheel upgrade worthwhile?
celica_gtx
New member
Chuck.hudson":32dhdoyf said:
I just talked to a guy from that gpopshop and he says they can do a 50 trim upgrade for the ct26 that can handle atleast 300 all wheel horsepower its 630 for the rebuild and wheel upgrade. Its no 200 bucks out the door but 630 isnt too bad i think i might give it a try at the begining of next year when i got the money and if i can get my car up and reliably running by then
Yea like I said I had throwen in stuff w the deal I think that what I originally got quoted aswell showing up to the door step w cash in hand is good too. I cranked it up to 14 the other day n its a blast. But u can tell it'll be more fun w supporting mods n a tune.
Chuck.hudson
New member
Well cool man I've tried calling that shop multiple times and couldn't get through I guess I'll have to man up and leave a vm did they give you any specs on the turbo build like what's a reliable hp output or the safest max boost or anything like that
celica_gtx
New member
There is a compresssor map on their page but other than that I'm not to sureim sure it can relate to ats ct27. But I can me wrong..
jwgt41
New member
The difference in compressor wheels
knowitalls
New member
If you do the upgrade, there is no reason to go with a compressor wheel larger than a TO4E-46 trim compressor wheel. Also, perform a 15 degree clip on the turbine wheel. The clip will allow you to run higher boost without it falling off until ~6000rpm which has been dyno proven to add ~ 15hp.
Top
