Installing FCD, Question about wiring.
Postby 1337computing » Fri Sep 27, 2013 1:08 pm
Got generic fcd pictured here:
Have question about installation. Are all the wires you have to splice into accessable in the engine bay? I know one is on the turbo pressure sensor but not sure about the others. Would like to get it installed today so any info would be great. Thank you!
1990 Celica All-Trac Turbo ST185
3" Berk DP, 3" Straight Piped, Magnecor Wires, EBC+
1337computing
Re: Installing FCD, Question about wiring.
Postby quieter » Fri Sep 27, 2013 1:46 pm
install it at the ECU. alot easier. if you dont want to splice you can use scotchlocks ( quick-connect)
just wondering what mods you have before even installing a FCD
i cant properly see the color of the wires with your picture. is it black red white and yellow? i see a hint of green
2011 BMW 535xi M pack (daily)
-Simon
quieter
Postby 1337computing » Fri Sep 27, 2013 2:21 pm
Brown white and blue I believe. I have install instructions from twos r us but colors dont seem to match up. Mods are in my signature.
1337computing
Postby CTechBlueDragon » Sun Sep 29, 2013 1:25 pm
It probably is not going to make any difference until you get a boost controller...
CTechBlueDragon
Images: 51
Postby 1337computing » Wed Oct 02, 2013 1:22 am
Have a boost controller, trying to make time to install. I'm gonna write a review up on it when done too. FCD is straight forward, just didn't want to tap into harness by ecu but it's whatever.
1337computing
