Blitz Nur Spec R
Blitz Nur Spec R
Postby 3SDNA » Wed Oct 09, 2013 6:59 am
Hello all,
I have purchased a 3'' down pipe for my All-trac, and want to upgrade the rest of the exhaust to a 3'' diameter as well.
I plan on purchasing the Track Forged 3'' mid-pipe, and I have been looking at the Blitz Nur Spec Exhaust on RHDJapan.com. The website lists the pipe diameter as 70mm(about 2.7 inches). Does anyone know if that is the bore(I.D) or are they talking about the O.D.? . I want to make sure this is going to work with the 3'' mid pipe.
I emailed RHDJapan, and they just sent me the same measurements(70mm) that are listed on the website.
Any help would be appreciated. Thanks.
http://www.rhdjapan.com/blitz-nur-spec- ... t185-62131
3SDNA
Re: Blitz Nur Spec R
Postby Eurus » Wed Oct 09, 2013 8:57 am
Looks like its the bore, based on the Blitz Uk site.
Nur Spec R exhaust sytem.
2 Piece sytem, polished SUS304 stainless steel
70mm bore pipwork
114.3mm Tailpipe
89DB with baffle inserted
Removable baffle included
Celica GT4, ST205, 3S-GTE
http://www.blitz-uk.co.uk/ProductItem-109.aspx
Eurus
Postby Meenya » Mon Oct 28, 2013 9:44 pm
You can also check into HKS silent catback...I believe it's actually 3" pipe compare to Blitz.
FYI neither of the 2 systems are true SS as the flanges are not SS. So depends on where do you leave and how long you plan to have the exhaust/car you might want to look into custom one.
Mike
93 Turbo 4WD
91 GTFour RC
07 R6
Meenya
Images: 19
Postby zero06 » Thu Apr 10, 2014 10:31 pm
I have the same setup, trackforged to blitz nut spec, everything fits up well no bottleneck.
Just a warning the car is loud with a 3" dp the silencer helps but greatly affects your performance/ wg setting.
zero06
Users browsing this forum: No registered users and 7 guests
