98+ 5sfe block
98+ 5sfe block
Postby zero06 » Tue Oct 15, 2013 3:38 pm
what Is needed to be done to a 98+ 5sfe block to create a 5sgte stroker.
I am under the impression that crank journals need to be ground and the obvious deck, bore and hone(s).
I am also aware of the grinding to the casting in the rear.
but is there anything that I'm missing over that is unnecessary on the 97 and below blocks?
I know all of our accessories will bolt to a pre-97 block.
I don't have a block infront of me to compare as I am weighing out going pre-97 or 98+
zero06
Re: 98+ 5sfe block
Postby sinerasis » Tue Oct 15, 2013 4:15 pm
You should be able to search Google and find all the info you need...
You need to machine the crank in both cases.
The reason the 98+ block is preferred is it has thicker cylinder walls, is reinforced between the water pump and cylinder, 1mm larger bore... and it's just newer.
Jeff
1989 ST165 Black
sinerasis
Re: 98+ 5sfe block
Postby GT4_DRED » Tue Oct 15, 2013 4:51 pm
You wont need to machine the crank, if you're using performance 5S rods and keeping the same rod length.
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Re: 98+ 5sfe block
Postby zero06 » Wed Oct 16, 2013 9:02 pm
I need some solid answers from people who have built a 98+ 5s-gte
zero06
Re: 98+ 5sfe block
Postby Overtriped » Wed Oct 16, 2013 10:16 pm
Check out Ryan's project. He is the only one I know.
90 ST185~205
04 Tundra V6 5spd 2wd
TOYOTA JUNKIE
Overtriped
Re: 98+ 5sfe block
Postby MWP » Thu Oct 17, 2013 1:41 am
There is no point whatsoever going pre-98... you would be silly to do so.
Im just finishing off a 2yr 5SGTE build, but mine is far from typical.
viewtopic.php?f=44&t=37056&start=30
Re: 98+ 5sfe block
Postby built2run » Fri Oct 18, 2013 3:18 pm
Sigh... Even at a bore size of 88mm the pre 98 5S-FE block in good condition will hold 800 whp, the 98+ block is more forgiving to tuner and user error due to the casting improvements and the whole reason to do a 98+ is to make 850 and above
Sure it's a great selling point for the ones who build them professionally (myself included) because it makes us more money but if you are going for less than 650-700 whp a well built 3S-GTE will do the job just fine.
ST165, black: parted and gone
ST165, white: sold to friend
built2run
Re: 98+ 5sfe block
Postby built2run » Fri Oct 18, 2013 3:21 pm
Unless you simply want to have a stroker or simply want to have higher displacement or say 300 rpm faster spool then by all means do a stroker. I just want people to know that you don't necessarily NEED a stroker. It is however nice to have and some prefer the feeling to the more rpm happy 2.0 setups
built2run
Re: 98+ 5sfe block
Postby Smaay » Fri Nov 08, 2013 10:54 pm
there is no such thing as a 5S stroker. its the 3S block that you stroke using a 5S crank.
2001 Celica GT-S 2ZZ-GTE
90 Celica All-Trac 3S-GTE
97 Supra 2JZ-GTE
97 Celica GT 3MZ/1MZ hybrid
Smaay
Re: 98+ 5sfe block
Postby built2run » Sat Nov 09, 2013 1:49 am
People understand "3s stroker" as any larger displacement 3S-GTE setup, even when using a 5S-FE block and crank or just the crank in the 3S-GTE block. No need to nit pick
built2run
Re: 98+ 5sfe block
Postby MWP » Mon Nov 11, 2013 1:09 pm
Smaay wrote:there is no such thing as a 5S stroker.
No, actually there is :shoots:
You can offset-grind the 5S crank big ends to gain even more stroke length.
With a 88mm bore, you can get close to 2400cc.
Re: 98+ 5sfe block
Postby aus jd 2703 » Tue Nov 12, 2013 1:20 am
What do your rod angles end up being like? Suspect torque monster with a 7000rpm max limit?
aus jd 2703
Re: 98+ 5sfe block
Postby built2run » Tue Nov 12, 2013 2:34 am
Offset grind would be 3mm tops with 3S-GTE rods, total cc would be about 2265 or so. Still making it a 2.3 and still capable of over 1000 whp and still able to rev up to about 8000 rpm for track use and going for broke in a drag race good for 9500 rpm rev limit
Piston speed is going to be pretty high at 9500 but still will hold for a while, at 8000 to 8500 it's still very capable and will be more reliable. But yes most people that do any sort of stroker weather it be the ATS style 2311 cc engine or the 5S-FE crank and 88mm bore "5S-GTE" usually stay at lower hp levels. As I said before usually a stroker is more for 750 and up whp. Sometimes not even then
built2run
Re: 98+ 5sfe block
Postby built2run » Tue Nov 12, 2013 3:51 am
But it's your money spend it how you like.
Oh and it's actually 2287cc with the 3mm offset grind and 88mm pistons
The max bore (reliable max) on a 5S-FE is 88mm and you would need a 97mm and higher stroke to be above 2350cc and qualifying as a 2.4 and I doubt a 97mm stroke would allow high rpm let alone simply fit in the block
built2run
Re: 98+ 5sfe block
Postby MWP » Tue Nov 26, 2013 4:38 am
The 5S has 54mm bigend journals, the 3S is 50mm.
Assuming the 5S crank is perfect, you could get very close to a 4mm offset grind which gives 8mm of extra stroke.
8mm of extra stroke (90.9+8=98.9mm stroke) at 88mm bore gives you 2406cc :wink:
The rod/stroke ratio is rather nasty, but there racing 5S's around running this long.
