ST165 code 54 fix (I searched)
Postby knowitalls » Sat Nov 09, 2013 5:14 am
Well When I got the car it came without the inter cooler and the motor was in pieces. So I did a front mount and have CEL code 54. I ready every post that I could find on this issue, but none were able to tell me what exactly I need to do. Do I have to go to the ECU? Can I just do it from the plugs that used to plug into the pump and level indicator? Do you ground it like some say or do you put a resistor in? What do these plugs look like?
Thanks guys,
K
If you didn't build it, it ain't yours.
knowitalls
Re: ST165 code 54 fix (I searched)
Postby brutekiller787 » Sat Nov 09, 2013 11:23 am
Step one bend paper clip to u shape
Step two jumper level connector
Step three wrap in electrical tape
Cheers
brutekiller787
Postby knowitalls » Sat Nov 09, 2013 11:02 pm
brutekiller787 wrote:Step one bend paper clip to u shape
Cheers
What does the plug look like? Anyone have a pic?
knowitalls
Postby brutekiller787 » Sun Nov 10, 2013 1:21 pm
One horizontal connector on top of one vertical. Plugs into the intercooler. Comes out of the harness with the coolant temp sensors around the coolant outlet elbow. Black plug. I dont have a picture though.
Should be the only unplugged two wire connector near the coolant elbow
Hope that helps
brutekiller787
Postby wakkjobb » Sun Nov 10, 2013 3:37 pm
Best I have for now:
Sensor is the rubber black/gray plug on top of the IC, its wiring goes down to the harness above the water neck. If you need more, I'll get actual pics today when I'm poking around the car.
MFIC at Rainbows and Unicorns Fabwerkz :D
Old build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=27648
New build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=42305
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby wakkjobb » Mon Nov 11, 2013 2:18 am
Moar better pics:
Old build:
New build:
Go-Fast parts:
siliconeintakes.com
wakkjobb
