relocating fan for fmic
Postby msanders2 » Wed Nov 13, 2013 8:28 pm
What are some good fans and sizes to put a slim pusher fan on the front of the radiator so I can run fmic pipes? Are the eBay fans anygood or just go with spal? Also what size fan are yall running?
msanders2
Re: relocating fan for fmic
Postby celica_gtx » Wed Nov 13, 2013 10:33 pm
I've been thinking the same but I'm gunna run a heat exchanger for a water to air set up..but w relocating them u still have to run the piping unless u clock the turbo ull have more room
transformation has BEGUN!!!
90GT W/ 90 3SGTE/ SOLD
91 ALL-TRAC 215 w 205 swapd
10 Scion Xb-kid hauler
celica_gtx
Postby underscore » Wed Nov 13, 2013 10:37 pm
I've got a single 12" Mishimoto puller that seems to work great, so a couple of decent 12" slim fans should do the trick. I wouldn't bother with Spal, last I checked they were very expensive.
Postby killemalltrac » Thu Nov 14, 2013 12:12 am
I got 2 flex a lite 12"ers for 150 bucks locally. And man do they work!
#80sMurderCar
killemalltrac
Images: 10
Postby celica_gtx » Thu Nov 14, 2013 1:01 am
Did u guus hard wire em or are they kicking on when the need too? I was gunna put on a bar n plate heat exchanger that looks like a FMIC to preserve the look yet have maximum cooling efficienty but yet not trying to impede the cooling of everything else
celica_gtx
Postby underscore » Thu Nov 14, 2013 2:05 am
Mines wired up to the stock system, so it kicks on when the stock one would have.
Postby killemalltrac » Thu Nov 21, 2013 7:30 pm
celica_gtx wrote:Did u guus hard wire em or are they kicking on when the need too? I was gunna put on a bar n plate heat exchanger that looks like a FMIC to preserve the look yet have maximum cooling efficienty but yet not trying to impede the cooling of everything else
Mine are hard wired and constant running.
#80sMurderCar
killemalltrac
Images: 10
Postby phattyduck » Mon Nov 25, 2013 5:35 pm
Mine uses the factory system for fan control during normal driving. I also have a switch inside the car that allows me to turn them on any time I want (say, idling in traffic, waiting in line for drag racing, or turbo-timer cool-down time). You just put a switch in line with either the AC high-pressure switch or the water temp switch and run the wires inside.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
