CS Cam Gear Induction
Postby Eurus » Thu Dec 12, 2013 12:36 pm
Can anyone explain/ show me how this tube (circled) connects to the Cam cover?
Any and all pictures will help; Ive spent a good 20 minutes, just to find this photo on here, through google.
Thank you.
Eurus
Re: CS Cam Gear Induction
Postby Tecker185 » Thu Dec 12, 2013 1:48 pm
Heat was a problem in rally with these cars. The timing belts where literally burning up. It's one of the provisions for the CS/RC model.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Postby phattyduck » Thu Dec 12, 2013 5:06 pm
Its held to the valve cover with one 10mm bolt. It directs air to where (on the rally cars only) there is a hole in the inner metal shield of the timing belt area. It is there on the street cars for homologation purposes but isn't functional.
So, on the street cars it does nothing (you don't want to have a bunch of dirt and water getting in there long-term). On the rally cars, it kept the timing belt area cool.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby Eurus » Fri Dec 13, 2013 11:40 am
Well I feel like a noob, with your answers. haha. I do understand what it was used for; however, I am interested in how it is directly connected to the cam cover. Pictures of that cam cover by itself would be the easiest way to understand, but I dont know what to search to bring an image up.
Eurus
Postby celi_wabbit » Fri Dec 13, 2013 12:58 pm
This only bolts in one way, there are no other way it will go if you have the bracket the came with it. As phattyduck said! only one bolt, if you have the original bracket.
Also, by looking at your picture, it needs to rotate about 180 deg.
1993 MR2 N/A - Sold
1995 Tacoma - Sold
1991 Celica Alltrac - Sold
1994 Celica GT - Project
2010 Mercedes-Benz
celi_wabbit
Postby phattyduck » Fri Dec 13, 2013 6:18 pm
Yeah, its hard to say anything else. One (or two?) 10mm bolt. It just sits on top there. I don't run it since there no place on my hood for it (ST205 motor):
You can see the bolt holes and slight wear on the valve cover where it touches if installed:
Of course, what I've shown you here and the picture you posted is for an ST205 motor. The ST185 CS is probably a bit different.
phattyduck
Postby athousandleaves » Sun Dec 15, 2013 3:38 pm
All the second gen engines that I've worked on have a functional opening in the timing cover for cooling the belt.
The RC/CS has the single snorkel and the regular ATA TMIC'd cars have a small rubber boot that directs air into the timing cover after it passes through the intercooler; part number 17971-88380.
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby Eurus » Mon Dec 16, 2013 6:25 am
athousandleaves wrote:All the second gen engines that I've worked on have a functional opening in the timing cover for cooling the belt.
That's quite interesting.
I guess I should point out some things to others who replied.
This is not my car pictured, I have a 165; the picture was pretty much the only image I could find of that piece attached to the car.
I posted just to see where the hole was in the timing cover, and how this "snorkel" attaches to it.
Thank you for all the replies.
Eurus
