Will a st185/st205 head fit on st165 block?
Postby knowitalls » Wed Dec 18, 2013 4:32 am
Will a st185/st205 head fit on st165 block? What about the MR2 heads? Has it been done before? If so, is it a worthwhile upgrade?
If you didn't build it, it ain't yours.
knowitalls
Re: Will a st185/st205 head fit on st165 block?
Postby monkey8oi » Wed Dec 18, 2013 6:37 am
Yes, they will fit.. I currently have an st205 head on a built st165 block..
monkey8oi
Postby brutekiller787 » Wed Dec 18, 2013 3:16 pm
Yes they all fit. Yes they are a worthwhile upgrade because they allow for the fitting of a greater selection of aftermarket cams. They are also a bit easier to find shimless buckets for, marginally. They are about the same though.
brutekiller787
Postby knowitalls » Sat Dec 28, 2013 6:59 am
What all needs to be changed over besides head, intake?
knowitalls
Postby quieter » Sat Dec 28, 2013 4:47 pm
gasket set. while your at it get a metal head gasket and maybe timing belt while your at it and water pump
2011 BMW 535xi M pack (daily)
-Simon
quieter
