Aftermarket wastegate for stock ct26?
Postby Gordon12 » Thu Jan 02, 2014 3:10 am
Hi guys I was wondering if they make an aftermarket wastegate for a stock ct26? My engine is out of a 88-89 Alltrac. I bought a stock wastegate but was sold the wrong. Might as well just get a good one now.
Gordon12
Re: Aftermarket wastegate for stock ct26?
Postby MWP » Thu Jan 02, 2014 4:22 pm
Postby Gordon12 » Thu Jan 02, 2014 4:47 pm
Won't work. I've looked at those. The bracket on it has that curve to it. Like the wastegate I already tried to install.
Gordon12
Postby Gordon12 » Thu Jan 02, 2014 4:48 pm
Gordon12
Postby Gordon12 » Thu Jan 02, 2014 4:49 pm
Mine is the one on theft. Has to be something like that.
Gordon12
Postby MWP » Fri Jan 03, 2014 1:56 am
Postby Gordon12 » Fri Jan 03, 2014 2:04 am
MWP wrote:http://www.ebay.com.au/itm/Kinugawa-Adjustable-Turbo-Actuator-TOYOTA-3S-GTE-GT4-ST165-CT26-/291044224835 ??
Says its for a ST165.
Curious. I didn't do the swap on my car. But I was told my turbo is out of a supra. Would that make a difference?
Gordon12
Postby MWP » Fri Jan 03, 2014 2:15 pm
Quite possibly, yes.
Im not too familiar with gen1's or the ct26's used on Supra's though.
Someone else here should know more...
Postby Gordon12 » Fri Jan 03, 2014 3:25 pm
I hope someone does. Been dealing with this forever now and I just want to get it fixed :(
Gordon12
Postby SkagTits165 » Sat Jan 04, 2014 12:51 am
I know that when i put a supra ct26 on my 88 st165, i had to majorly change the stock actuator bracket to fit the supra one.
SkagTits165
Postby Gordon12 » Sat Jan 04, 2014 1:14 am
vukawich wrote:I know that when i put a supra ct26 on my 88 st165, i had to majorly change the stock actuator bracket to fit the supra one.
Yeah that's what my motor is out of. 88 alltrac. Did your wastegate look like mine in picture? Currently installed is the one on left. The one with less of a curve.
Gordon12
Postby CSAlltrac » Sat Jan 04, 2014 2:38 am
Forge makes a nice unit that utilizes the stock mounting arm. It requires you to remove the stock diaphragm, which is a bit of a pain in the ass to do cleanly, but it can be done.
Postby MWP » Sat Jan 04, 2014 3:03 am
The Kinugawa actuators are screwed to the back of the supplied bracket.
You could remove the stock actuator from its bracket, then bolt the Kinugawa actuator onto it.
Postby Gordon12 » Sat Jan 04, 2014 3:03 am
CSAlltrac wrote:Forge makes a nice unit that utilizes the stock mounting arm. It requires you to remove the stock diaphragm, which is a bit of a pain in the ass to do cleanly, but it can be done.
If you have to use your old than what are you really buying? Just the bracket? Because my old wastegate is toast bad diaphragm believed.
Gordon12
Postby CSAlltrac » Sat Jan 04, 2014 3:35 am
You have to use the stock mounting hardware is what I'm saying. It replaces the diaphragm only, not the bracket.
http://www.forgemotorsport.com/content. ... ct=FMACGT4
