Aftermarket wastegate for stock ct26?
Re: Aftermarket wastegate for stock ct26?
Postby Gordon12 » Sat Jan 04, 2014 4:48 am
MWP wrote:The Kinugawa actuators are screwed to the back of the supplied bracket.
You could remove the stock actuator from its bracket, then bolt the Kinugawa actuator onto it.
Oh that I did not know.
Gordon12
Postby Gordon12 » Sat Jan 04, 2014 4:52 am
CSAlltrac wrote:
Gordon12 wrote:
CSAlltrac wrote:Forge makes a nice unit that utilizes the stock mounting arm. It requires you to remove the stock diaphragm, which is a bit of a pain in the ass to do cleanly, but it can be done.
If you have to use your old than what are you really buying? Just the bracket? Because my old wastegate is toast bad diaphragm believed.
You have to use the stock mounting hardware is what I'm saying. It replaces the diaphragm only, not the bracket.
http://www.forgemotorsport.com/content. ... ct=FMACGT4
Oh ok I see. Is this a bolt to original bracket as well? After removing my old one from the bracket of course.
Gordon12
