Upgraded WTA intercooler hoses
Postby Eurus » Fri Jan 03, 2014 9:03 am
Im looking to upgrade my IC to HE hoses, as my water pump (bosch cobra) has larger inlet/ outlet fititngs. Has anyone done this on a st165, and kept the stock intercooler? If memory serves correctly, the pump is 3/4", but the stock is smaller (1/2"?); what would be the best way to go about keeping the stock IC but going with a larger hose?
Should I just use a small bit of stock size hose off the IC and just use reducer fittings, or would that have some negative affect on the flow of coolant?
Thanks for any info.
Eurus
Re: Upgraded WTA intercooler hoses
Postby adrian88alltrac » Mon Feb 10, 2014 12:18 am
I just redid the two hoses going from the metal pipes from the ic to the pump and it was 3/4. But idk if the rc is different.
adrian88alltrac
Images: 4
