Help with ST215 swap (hard line related)
Postby cbrkp » Mon Jan 06, 2014 8:12 pm
Hey all I need help identifying what a particular sensor is and what the open line is suppose to be connected to as I have no open ports to connect it to.
The close up picture is the tps sensor and throttle body
1. Red arrow - where do I connect this hard line to?
2. Green arrow- what sensor is this? is it IAC?
swap is done into a celica alltrac
engine bay pic for reference
cbrkp
Re: Help with ST215 swap (hard line related)
Postby ___Scott___ » Tue Jan 07, 2014 12:30 am
The sensor is the throttle position sensor.
Sorry I can´t help on the open hard line.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby Speedricer » Tue Jan 07, 2014 4:43 pm
That hard line goes to the air filter box. That port is controlled by the ecu and is open when your car is cold and closes when it warms up. If you start your car you will hear air being sucked in then it will close when the car reaches temp. I left mine open, probably not the most correct thing to do but it works.
92 ST185 White
3" full exhaust
Megan Racing Springs
FMIC
st215 swap
Speedricer
Images: 8
Postby Tecker185 » Tue Jan 07, 2014 4:53 pm
Yeah it's your iac it just runs to you intake tube. A lot of people just throw a filter on it an run it.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Postby phattyduck » Tue Jan 07, 2014 6:30 pm
That should be the IAC. You want to have that have access to filtered air (it is generally sucking air into the engine), with either a small breather filter or back to the intake.
This is how I did it on my ST205 engine, but the ST215 is similar. The larger line to the turbo intake is for the crankcase vent, the smaller is for the IAC and PS idle-up (that the ST215 doesn't have).
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby cbrkp » Sun Jan 12, 2014 3:01 am
thanks a bunch ya'll hopefully i get this it running this coming week its been a long hate affair lately...hopefully that love comes back
cbrkp
