Cylinder head serial numbers
Postby knowitalls » Thu Jan 16, 2014 5:40 am
I there a way to identify the year of a head by using the numbers on the head?
One of mine is 11111-88380.
The other is 11111-88383
Searched but to no avail.
If you didn't build it, it ain't yours.
knowitalls
Re: Cylinder head serial numbers
Postby Meenya » Fri Jan 17, 2014 12:43 am
knowitalls wrote:I there a way to identify the year of a head by using the numbers on the head?
Not sure about part numbers but later years head would get exhaust manifold with 9 studs instead of 7.
Mike
93 Turbo 4WD
91 GTFour RC
07 R6
Meenya
Images: 19
Postby Spectra1 » Fri Jan 17, 2014 3:24 am
This should help you out some
http://www.alltrac.net/phpBB2/viewtopic.php?f=50&t=38772
The 11111-88383 is listed as a JDM head. I dont have the parts numbers for the US spec heads but if the 11111-88383 one does not have EGR porting then it is a 1990 JDM head. If it does then it is us spec, either way that one is a 2nd gen non RC head. As for the 11111-88380 I could not find any info on it.
93 St185 DD
90 ST185 - Project
Spectra1
