5sfe Rods 1000hp?
5sfe Rods 1000hp?
Postby xabin165 » Sat Feb 08, 2014 1:21 am
I´am wondering if there is any one how now any good 5SFE rods that holds for 1000hp except Pauter.
Celica GT4 st185 5s-gte BW s468 :)
Supra mkiv Jza80 2jz-gte
xabin165
Re: 5sfe Rods 1000hp?
Postby spitfiremk16 » Sat Feb 08, 2014 1:59 am
Pauter makes the only aftermarket 5sfe rods. So thats your only choice. Unless you have a machine shope cut your rod journals on your crank down to accept 3sgte rods. Then you can run 3s rods. Your planning on making 1,000 hp? Not many folks have done that on a 5s/3s.
spitfiremk16
Postby UtahSleeper » Sat Feb 08, 2014 3:13 am
Has anyone broken 1000 HP on an S motor? I know there are some 900's, but thats it.
UtahSleeper
Postby New Guy » Sat Feb 08, 2014 3:53 am
Pat did ~900awhp, which is easily over 1k at the crank.
Proud owner of an ESV220x.
New Guy
Postby GT4times2 » Sat Feb 08, 2014 5:19 am
And some other 3SGTE powered RWD Corollas down here.
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby ALLensTRAC » Sat Feb 08, 2014 5:45 pm
Rasado Racing has with their drag car I believe although I think they're using 2RZ engines now.
Allen
ALLensTRAC
Postby CMS-GT4 » Sat Feb 08, 2014 5:50 pm
Top Secret used to sell 1000hp capable 3sgtes based on what they did with their 200+mph 3s supra.
Postby xabin165 » Sat Feb 08, 2014 10:35 pm
okej but i have already bought CP piston for 5s rods so cut rod journals is no alternative. has anyone tested these rods?
http://www.ebay.com/itm/Toyota-2-2L-MR2 ... c0&vxp=mtr
xabin165
Postby New Guy » Sun Feb 09, 2014 2:44 am
3S and 5S rods are the same length bore center to bore center- why couldn't you use 3S rods?
New Guy
Postby Mafix » Sun Feb 09, 2014 9:31 pm
sounds like too lazy to turn the crank down, lol.
Postby mikahogl » Fri Feb 21, 2014 9:35 pm
Hello! I dont know why everyone running 5s-gte have to grind down the crank. if you do this you have to reharden the crank and you get a smaller surface for the rods to lube and a smaller surface for the power from the pistons to spread on the crank.
We have rods here in sweden custom for the 5s, tested on volvos to 1100bhp and audi 5cylinder to 1300hp, for the same price as eagle.
When grinding down the crank you also weakens you crank, i just think using 5s rods is a much better idea.
mikahogl
Postby lumbercis » Fri Feb 21, 2014 9:48 pm
There's not been any 1000whp 3sgtes on gas. I think Pat's is probably the highest. Some methanol drag cars have gone over (Rosado etc.) but methanol motors are somewhat of a different bag of beans.
Caldina powered...
lumbercis
Postby Mafix » Sat Feb 22, 2014 9:17 pm
no they are not, as far as the bottom end is concerned. they all use STOCK cranks unless they are running a stroker. all the same stresses and those guys run much higher rpm (srt runs up to 12k and paradise is at 10k). they both use custom made aluminum rods, off the shelf arias pistons, and stock cranks. low boost is 36 for both. high boost i'm not allowed to divuldge (it shames deisels)
Postby Hic » Wed Feb 26, 2014 2:55 am
Best is to use supra rods and custom piston.
Hic
