Opinions on what to do with BHG or the like
Postby chiefum » Fri Mar 21, 2014 1:07 am
Hello, my name is Brandon. I bought a 1988 Toyota All Trac that is overheating. My mechanic said it is getting aeration in cooling system under load. I am totally new to working on Japanese cars. I would like to know what options I should look at? Do I go further to see if it is a BHG or something else and repair what I have. Or do I look into engine swaps. What are some options for changing the engine or trans or both. Do I stick with the ST165 or what possibilities are out there for swaps...ST185 or ??? I appreciate any help I can get as I am new to these cars. Sorry if I sound like a newb....I have posted some pics in the introduction area of the forum.
chiefum
Re: Opinions on what to do with BHG or the like
Postby 88gt4DE » Fri Mar 21, 2014 1:24 am
Kinda depends on your goals for hp and performance and if you have access to a garage to work on it a little at a time. Lots of directions you can go in but sometimes gonna tear it apart a little to see what ya have to work with. Btw ... Welcome and good luck with the project. 8)
Postby chiefum » Fri Mar 21, 2014 1:45 am
I guess I would like to improve performance from stock....I am not looking at anything crazy like 500hp...I wouldn't mind getting into the 250hp - 300hp range....but I am not sure what that would all involve. I purchased the car in Wisconsin but the car is from California, so it is rust free and in good shape and has around 130,000 miles. I do have a garage to work in...I am used to working on older American cars...but my brother in law has experience with some Japanese cars.
chiefum
Postby 88gt4DE » Fri Mar 21, 2014 1:50 am
Once you get all the crap around it out of the way exhaust , turbo , intake its really not that bad to take apart. If you take the head off alone the worst part is the rear intake support bars. Rust free is a huge plus to start and 250 -300 is a good range to think of if yer no going for a monster. Same page I'm on 8)
Postby underscore » Fri Mar 21, 2014 3:53 am
Definitely confirm what the issue is before you go any further, get a compression and leakdown test for starters.
Postby chiefum » Mon Mar 24, 2014 10:14 pm
Where would I look for an engine to swap? I have seen some on ebay....has anyone from here purchased from ebay? Is there a good seller? I think I may be leaning towards swapping out to a st185...but I'm not sure yet. I just want to be able to drive my new toy...lol
chiefum
Postby soarer.jzz30 » Mon Mar 24, 2014 11:33 pm
Just get a st205 gen3. Retains your wta set up. Plus give you 265ho stock. Can't lose
soarer.jzz30
Postby chiefum » Mon Mar 24, 2014 11:55 pm
soarer.jzz30 wrote:Just get a st205 gen3. Retains your wta set up. Plus give you 265ho stock. Can't lose
Are there any wiring issues that would need to be addressed with the st205... I will try to search for some more swap info...but that sounds better to me. Thank you.
chiefum
Postby underscore » Tue Mar 25, 2014 1:40 am
Unless his problem is something minor, in which case he'll waste a bunch of money.
Postby soarer.jzz30 » Tue Mar 25, 2014 2:03 am
Not sure that swap is a waste of money.,
soarer.jzz30
Postby underscore » Tue Mar 25, 2014 2:56 am
It is if his current problem is something easy to fix. Believe me, I've both lost and saved large amounts of money from small issues being misdiagnosed as larger ones. I'd be 100% sure of the problem before pulling out the motor and doing a swap.
Postby soarer.jzz30 » Tue Mar 25, 2014 4:03 am
If you've got the money to spend then hey why not. But if he just wants to get her going again and get the gen1 to 300 hp I suppose it would be worth at least determining the problem first
soarer.jzz30
