AF 9.6 @ wot @ mid rev's ( gen2 3sgte)
Postby Robin-evo6rs2 » Fri Mar 21, 2014 6:22 pm
Hello,
I just got a gen2 3sgte power'd Rolla.
now i start to log the car with a lm2 wideband meter.
Instal a elektro boost controler to turn op the boost.
In the firt run i ran @ 0.5 bar ( 7-8 psi) i see the AF going to 9.6 as soon as i go WOT.
It is just a dip but offcorse the engine does not like that AF.. the power goes down as the engine gets flooded.
After the dip the AF goes to a more healty 11 and the engine takes off..
What can cause this?
Cheers
Robin
Robin-evo6rs2
Re: AF 9.6 @ wot @ mid rev's ( gen2 3sgte)
Postby gpmarzan » Thu Apr 17, 2014 12:23 pm
Robin-evo6rs2 wrote:Hello,
Cheers
Robin
What ECU are you using in this 3S powered 'Rolla'
Patrick M.
st165
gpmarzan
Postby Robin-evo6rs2 » Thu Apr 17, 2014 3:16 pm
It was the stock jdm one..
cut it off :)
almost runing a DTA ecu now :)
Robin-evo6rs2
