WTA setup Wiring up a fan?
Re: WTA setup Wiring up a fan?
Postby Spectra1 » Wed Apr 02, 2014 4:40 pm
underscore wrote:Ford doesn't actually make the exchangers you know...
Who makes it?
93 St185 DD
90 ST185 - Project
Spectra1
Postby underscore » Wed Apr 02, 2014 5:00 pm
I dunno, some sort of cooler manufacturer. If you get an aftermarket one it definitely isn't from Ford.
Postby Spectra1 » Wed Apr 02, 2014 5:43 pm
underscore wrote:I dunno, some sort of cooler manufacturer. If you get an aftermarket one it definitely isn't from Ford.
Ya I figured almost any aftermarket cobra heat exchanger would not be made by ford, thats kind of a given. I think that most references on here about using cobra heat exchanger are referring to the oem stock unit because they are cheap, functional, and easy to get because of all the ford guys upgrading.
So are you saying the stock OEM unit is not made by ford? Just curious how you knew that?
93 St185 DD
90 ST185 - Project
Spectra1
Postby underscore » Wed Apr 02, 2014 6:38 pm
Because most manufacturers farm stuff like that out. It might be made by Ford, but I'd guess it's most likely made by somebody else.
Postby phattyduck » Wed Apr 02, 2014 6:47 pm
The OEM Cobra heat exchanger is made by Garrett and is very good for its size. The Cobra guys are upgrading because they are often pushing 500+HP...
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby celica_gtx » Wed Apr 02, 2014 7:48 pm
Good to know. From browsing around they are up there in price. Im prob just gunna pick one up from frozen boost.
transformation has BEGUN!!!
90GT W/ 90 3SGTE/ SOLD
91 ALL-TRAC 215 w 205 swapd
10 Scion Xb-kid hauler
celica_gtx
Postby celica_gtx » Thu Apr 03, 2014 6:02 am
came across this..other than it being ebay i like the set up.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... ink:top:en
or frozen boost w fan +22
http://www.frozenboost.com/product_info ... 29cbd0995d
im also in the hunt for an ats TB inlet that i can chop up to hook up the intercooler.
or the correct inlet.
celica_gtx
Postby phattyduck » Thu Apr 03, 2014 4:33 pm
This is one of those places where you get what you pay for... I'd go for something specifically meant for water/coolant instead of oil. If it comes with a radiator cap, just run a higher pressure one than your fill location.
phattyduck
Postby celica_gtx » Thu Apr 03, 2014 8:07 pm
phattyduck wrote:This is one of those places where you get what you pay for... I'd go for something specifically meant for water/coolant instead of oil. If it comes with a radiator cap, just run a higher pressure one than your fill location.
The more I dig n read around I seen alot of different things. Frozen boost has there's labeled as water/oil coolers. And of course ebay list it how ever.
Then using an ac condenser would work too even its a gases conversion to liquid.
I guess im just thinking of volume at this point I dont want it super thin or to big that its barely cooling.
Just tryin to narrow my options in an affordable way.
celica_gtx
Postby phattyduck » Fri Apr 04, 2014 4:03 pm
Yeah, you'll want something that has as much frontal area as possible so it doesn't have to be too thick. CXRacing has a few options that might work for you too.
phattyduck
Postby underscore » Fri Apr 04, 2014 4:14 pm
Here's that post about using another cars rad for the HE, it's an Audi 100 rad viewtopic.php?f=7&t=40781&p=414896&hilit=rad#p414896
edit: A Prelude one works as well viewtopic.php?f=7&t=45415&view=next
Postby celica_gtx » Fri Apr 04, 2014 11:25 pm
phattyduck wrote:Yeah, you'll want something that has as much frontal area as possible so it doesn't have to be too thick. CXRacing has a few options that might work for you too.
underscore wrote:Here's that post about using another cars rad for the HE, it's an Audi 100 rad viewtopic.php?f=7&t=40781&p=414896&hilit=rad#p414896
Nice find n read. Too bad they are that the sacrifice of losing AC.. once i get my motor back in ill get some better ideas on space
celica_gtx
Postby celica_gtx » Sun Apr 06, 2014 8:31 pm
Packed full of knowledge now I found a cobra heat exchanger from another member on here so I will have that paired up w a Bosch pump..it'll be awhile before its all in my motor is still out of my car so once I get it all in ill try to get some temp readings by then it should be full blown out summer. Nice n hot
U guys are running a 50/50 mix right for the coolant?
celica_gtx
Postby WideFNopen » Sun Apr 06, 2014 10:24 pm
I run stuff called "40 Below" in my wta. Seems to work well.
https://www.facebook.com/peakcityrally
http://cdn.makeagif.com/media/1-12-2015/ZMp5Gn.gif
WideFNopen
Postby underscore » Mon Apr 07, 2014 1:34 am
I run Toyota Super Red.
