odd ideas for weight reduction ???
Re: odd ideas for weight reduction ???
Postby jsd » Mon Oct 27, 2014 4:25 am
I got this off of a facebook group so this is not my idea and I don't take credit but I wanted to run this by you guys. Picture is also not mine.
So the top starter is from an st182 with a 5sfe and the bottom from an 02 V6 camry with a 3mz. Apparently it is 4lbs lighter than the stock one but I'm not sure how the 5sfe and 3sgte starters compare. The smaller starter bolts right on to the 5sfe so I assume it will on the 3sgte also but I'm wondering if it will line up with our flywheel.
jsd
Postby CMS-GT4 » Mon Oct 27, 2014 1:09 pm
I didn't see how that project ended. I was curious if he had to extend the gear or if everything bolted up.
I know the RC and 205 also have smaller starters but this might be a cheaper alternative. Supposedly a more reliable tech too.
Postby jsd » Mon Oct 27, 2014 1:33 pm
I'm going to get one soon and try it out. I noticed no 02 model came with a 3mz so I'm going with an 06 model. It's listed as 1.7KW vs 1.4 stock
jsd
Postby underscore » Tue Oct 28, 2014 12:00 am
Since the 5S and 3S can interchange transmissions and flywheels I don't see why you couldn't interchange the starters.
Postby MWP » Tue Oct 28, 2014 12:43 am
Im using a starter from a 1MZ.
Its a similar size to the original though.
