Oil feed/return
Oil feed/return
Postby fwame_dwagon » Sat May 17, 2014 12:37 am
Does anyone make a kit for pur cars other than kinugawa? This looks like it will break pretty easily [attachment=-1]uploadfromtaptalk1400290662096.jpg[/attachment]
fwame_dwagon
Re: Oil feed/return
Postby ALLensTRAC » Sat May 17, 2014 10:19 am
I believe KO racing makes a kit as well as ATS racing. On my TDO6 kit I got all my lines from ATS.
Allen
ALLensTRAC
Re: Oil feed/return
Postby zero06 » Sat May 17, 2014 12:20 pm
I had gotten a much nicer style one when I had a ct27 from a supra store
http://www.driftmotion.com/CT26-Oil-Drain-Feed-Flange-p/dm398.htm
It's much higher quality than that ebay one. Specifically the feed line doesn't look like it'd snap off.
zero06
Re: Oil feed/return
Postby fwame_dwagon » Sat May 17, 2014 1:07 pm
zero06 wrote:I had gotten a much nicer style one when I had a ct27 from a supra store
That one looks pretty good. You didn't have clearance issues with the fitting being so close together?
fwame_dwagon
Re: Oil feed/return
Postby zero06 » Sat May 17, 2014 1:48 pm
You have to put the feed line on before the return.
At first I was concerned about the slight restriction on the -10 return line vs factory but it worked fine, no seal issues.
It's much easier to remove your turbo with this setup, just disconnect lines at the engine side and pull the turbo, manifold, and dp right out of the car.
zero06
Re: Oil feed/return
Postby fwame_dwagon » Sun May 18, 2014 10:34 pm
zero06 wrote: It's much easier to remove your turbo with this setup, just disconnect lines at the engine side and pull the turbo, manifold, and dp right out of the car.
That's what I'm shooting for. I bent the hardlines taking off my turbo.
fwame_dwagon
Users browsing this forum: Google Adsense [Bot], GTSfreak, jr32 and 1 guest
