Catch Can Filling
Catch Can Filling
Postby cmonteiro1 » Mon May 19, 2014 12:42 am
Been a while since I've posted but wanted to get some feedback from the pros. I'm finding my catch can is filling up with oil very quickly and I wanted to check on what the potential causes could be so I could start my process of elimination.
Thanks for any feedback.
Courtney
1991 ST185
Mods:
Aussie DP, 3in Exhaust, Wideband A/F, BayArea FMIC, HKS SSQ Blow Off Valve, Forge Waste Gate Actuator, AEM ECU, SARD 800 , Walbro Pump, ATS Fuel Rail Mod, ATS Fuel Pres. Reg. Mod., 60 trim upgraded ct26.
cmonteiro1
Re: Catch Can Filling
Postby celicast184 » Mon May 19, 2014 2:15 am
When I had that issue, it was because I had blown ringlands. The pressure will escape from the cylinders and into the crankcase. Presure pushed out lots of oil out the vent tube and into my catch can. So I recommend a compression test on ur cylinders
I <3 MY ST214
celicast184
Postby brutekiller787 » Mon May 19, 2014 3:57 pm
celicast184 wrote:When I had that issue, it was because I had blown ringlands. The pressure will escape from the cylinders and into the crankcase. Presure pushed out lots of oil out the vent tube and into my catch can. So I recommend a compression test on ur cylinders
Yes x2. Happened to me as well
brutekiller787
