Side feed intake w/WTA IC
Postby ST165Sleeper » Mon Jun 02, 2014 5:43 am
Anyone have an idea on how difficult it would be to switch to a side feed intake and still run a WTA ic. I want keep the wolf in sheep's clothing theme if at all possible. This of course would be for the 165.
ST165Sleeper
Re: Side feed intake w/WTA IC
Postby RedCelicaTRD » Mon Jun 02, 2014 7:59 am
I've thought about doing this with an ST205 core. Would need to cutoff and weld shut the current outlet, cut open a new outlet, and then weld on the required pipe to connect to the side feed. However, I'm not sure how well the new setup would work. The flow would no longer be "across" the internal heat exchanger so there might be some performance loss, but only real way to find out is to test it.
Postby TRDTurko » Mon Jun 02, 2014 1:36 pm
why not just use an upgraded center fed manifold?
88 Celica GTS - RIP
93 Honda Civic - RIP
85 Honda Civic - Sold
08 Mazda 3 - Daily
TRDTurko
Postby ST165Sleeper » Mon Jun 02, 2014 3:03 pm
Center feed I takes tend to cause cylinder 3 to run lean.
ST165Sleeper
Postby UtahSleeper » Mon Jun 02, 2014 3:50 pm
Couldn't you just make an aftermarket WTA intercooler work, or are you trying to use a stock WTA?
UtahSleeper
Postby eric thompson » Mon Jun 02, 2014 5:12 pm
See image
(15.18 KiB) Not downloaded yet
ST165-PARTS-RED
NEED ONE MORE FOR STREET:)
https://www.youtube.com/watch?v=w-RCuV_Hmqk (ITS miata 6spd,4.78 rear, shitloads of fun!! multiple wins and track records in 2014)
eric thompson
Images: 6
Postby underscore » Mon Jun 02, 2014 5:37 pm
I thought the center feed was only an issue on higher power builds? I've heard of somebody settings up their EMS to run extra fuel to 3 to cancel out the lean issue, I think you would need individual EGT probes on each cylinder tho.
Postby zero06 » Tue Jun 03, 2014 1:18 am
I'm doing it on my car, but mines a 185. I have an rmr side feed and I'm doing a custom manifold moving the turbo farther to the drivers side. This will make the w2a IC more feasible and there will only be 1 90 degree turn after the turbo. I am also doing this to retain AC.
I am using a aftermarket IC core and fabbing my own piping, I don't like the idea of those barrel style IC's I feel the exchange rate would be insufficient
I'll post a picture when I have it done
zero06
Postby celica_gtx » Tue Jun 03, 2014 3:57 am
U looking for something like this? I have one laying around..
http://www.frozenboost.com/product_info ... f612bfking
transformation has BEGUN!!!
90GT W/ 90 3SGTE/ SOLD
91 ALL-TRAC 215 w 205 swapd
10 Scion Xb-kid hauler
celica_gtx
Postby MrMcQuacker » Tue Jun 03, 2014 4:07 am
People only switch to side feed because they are going front mount. If you want to stick with the factory wta set up just stay with it. You don't have to worry about that when you are worrying about leaning out cylinder 3. That is your fuel rails problem. Go with a top feed fuel injection which will also aid you a better free flowing rail. They're are tons of people running Lots of AWHP using the stock intake and exhaust manifold. Just my 0.2 :)
MrMcQuacker
Postby psipwrd » Fri Jun 06, 2014 8:52 pm
I was looking at the frozen boost and pwr WTA intercooler cores. I wanted to do something similar but I wouldn't route the cold pipe over the exhaust manifold. I also thought about getting a bigger core and mounting it where the battery is, and relocate the battery to the trunk...
psipwrd
Postby Mafix » Fri Jun 06, 2014 11:33 pm
this has been done many times. most people use a barrel style intercooler where the air filter normally sits.
Postby celica_gtx » Sat Jun 07, 2014 4:48 am
this is my fav set up if ur going that route.
viewtopic.php?f=14&t=46743
or this i originally bought this to run a set up like this but goin w an RC tmic
celica_gtx
