Anyone with a clocked wastegate bracket
Re: Anyone with a clocked wastegate bracket
Postby msanders2 » Wed Jul 16, 2014 10:03 pm
Mr Alltrac, I think it would be easier if you pm Klue, as you would be the one actually making the brackets for us fine folk.
msanders2
Postby CTechBlueDragon » Thu Jul 17, 2014 2:03 pm
I have had 2 different types fabbed up for my car. For CT26 based housings you can use the 3 mounting points on the compressor to make a decent bracket. But with a ct20b it becomes more complicated because of only 2 mounting points which are basically useless once you clock it. For the 20b I made 2 pieces, one goes down to the mount on the bottom of the exhaust housing that supports the turbo for the top hole on the wastegate and I made one to connect to the tranny for the bottom hole. Also another problem the housing gets fatter as you rotate it so the stock bracket has to be trimmed on the back which weakens it. I had access to a plasma cutter and breaks and stuff when I made the last set of mounts now I do not. I can post some pics if you guys are interested.
CTechBlueDragon
Images: 51
Postby Mr Alltrac » Thu Jul 17, 2014 2:56 pm
Please do, some measurements would be great too. :)
Mr Alltrac
Postby FC Zach » Tue Jul 29, 2014 2:49 pm
Not sure if these pics would help or not but I had found these somewhere on the forum while searching a while back. .
(55.79 KiB) Not downloaded yet
(50.39 KiB) Not downloaded yet
(59.65 KiB) Not downloaded yet
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby FC Zach » Tue Jul 29, 2014 2:54 pm
Last pic from the same build above.
Here's another pic I had saved for an idea on how to do the index, this setup looks easier to do for those without a welder.
FC Zach
Images: 9
Postby Mr Alltrac » Tue Jul 29, 2014 4:06 pm
I'm looking for a fmic right now, this weekend I will probably pull my car apart and build a template hopefully, the seller I'm talking to finds his piping so I can make sure it works perfect.
I'm hoping I can make one that clears everything and will run with the turbo in factory postion just with a detached wastegate, so I can start replicating them. I'll check to make sure it clears with turbo clocked before I start my little production run of them. Hopefully I can one up with some pictures by this weekend.
Mr Alltrac
Postby gt4tified » Wed Jul 30, 2014 10:42 am
Subscribed.
+1 for clocked ct20b wg bracket.
gt4tified
Images: 5
Postby Mr Alltrac » Thu Jul 31, 2014 10:08 pm
Is the ct20 located in the same place as the ct26?
Mr Alltrac
Postby UtahSleeper » Fri Sep 12, 2014 7:35 pm
Love the simplicity of the second mount for the wastegate. I may have to try and do this.
UtahSleeper
