Rebuild 3s-gte. What to upgrade?
Postby toddy2 » Mon Jul 21, 2014 11:14 am
Hi,
I'm going to Rebuild my 3s-gte, and I would like to know what kind of improvements that would be advisable.
I will stick with Stock ECU, IC, CAMS.
But thinking of Wiseco pistons and ct20b turbo. Is this a smart upgrade?
And is it other things that would be a smart upgrade?
Car is a Celica gt4 CS. Have 3" exhaust all the way and cat has been moved.
Not after to much power, but as much as possible with Stock ECU, IC and CAMS.
What about transmission? Car has rolled 250k km. Upgrade kit? Change diferential?
What parts should be considered changed?
Know this maby could been posted in maintanence, but I'm after some more POWER and more effecient drivetrain without too heavy pricetag.
Cheers
toddy2
Re: Rebuild 3s-gte. What to upgrade?
Postby msanders2 » Mon Jul 21, 2014 12:27 pm
Weisco pistons and eagle rods would be a good upgrade. Get some good bearings like acl or clevette. If your keeping stock cams no need for crazy head work. Some Engle valve springs would be good to help prevent valve float. If your going Ct20b I would get some 550cc injectors off a supra and a walbro or supra TT fuel pump. Maybe a ats bored rail. Then just normal stuff Timing belt, water pump, all the seals and gaskets. Get OEM stuff from Toyota and you won't regret it.
msanders2
Postby toddy2 » Mon Jul 21, 2014 12:38 pm
Sounds like what I'm after.
So no problem going for 550cc with Stock ECU?
toddy2
Postby underscore » Mon Jul 21, 2014 6:51 pm
If you're tearing it completely down I'd replace the sensors that run to the ECU for control as well (water temp and such).
Postby msanders2 » Mon Jul 21, 2014 7:24 pm
Should be fine on stock ecu. I would also do Arp head studs and a Cometic or other brand steel head gasket.
msanders2
Postby Pipedreams » Mon Jul 21, 2014 8:19 pm
You can´t run 550cc injectors on stock ecu. It will run very rich.
Valvefloat will not be an issue as you won´t raise the rpm limit so springs are not needed.
Stock rods are good for over 500hp so that´s also a bit of a waste of money.
Pistons, metal headgasket, ARP headstuds and your good.
And as mentioned, buy the gasket kit from toyota. Nothing beats oem.
Pipedreams
Postby msanders2 » Mon Jul 21, 2014 10:48 pm
If your going to be in the high rpm range frequently, upgrade your valve springs. I've seen the OEM ones break. Also brand new rods might be capable of holding 500hp, your rods have over 200k miles. They do get weaker over time going through all those heat cycles. If your going to have the block torn down anyways, better safe then sorry. Upgrade your rods. Most rods come with arp rod bolts too, so they are stronger then OEM.
msanders2
Postby Pipedreams » Tue Jul 22, 2014 2:06 pm
Old used rods can handle 500hp and he wont be anywhere near that with a ct20. The rods will outlive the car.
Pipedreams
Postby toddy2 » Tue Jul 22, 2014 5:22 pm
Thank you guys!
I will stick with Stock injectors, but will go for CT20B and Wiseco pistons. ARP studs, good quality bearings and some good Quality gaskets.
toddy2
Postby underscore » Tue Jul 22, 2014 5:39 pm
While the injectors are out, be sure to get them cleaned and flow matched.
