Piston damage
Piston damage
Postby toddy2 » Tue Jul 22, 2014 5:07 pm
Please let me know if the scratches on the side wall are something to worry about?
toddy2
Re: Piston damage
Postby Mr Alltrac » Tue Jul 22, 2014 5:10 pm
If that's a brand new part I would exchange it for a new one.
I think as long as there isn't any burrs that will run the walls in your block, an the piston rings aren't damaged I think you are ok. Not 100% sure tho.
Mr Alltrac
Re: Piston damage
Postby toddy2 » Tue Jul 22, 2014 5:55 pm
Only been used for one dyno pull.
toddy2
Re: Piston damage
Postby Mr Alltrac » Tue Jul 22, 2014 7:03 pm
Was the damage there previously? Was there trash or metal that got in your cylinder? Any damage to the cylinder walls?
Mr Alltrac
Re: Piston damage
Postby toddy2 » Tue Jul 22, 2014 7:37 pm
Don't know about cylinder wall or trash. New pistons installed before dyno pull. New build engine. The guys at the chop doing the pull thought it was running lean. But there were oil in the water or the other way round.
toddy2
Re: Piston damage
Postby klue » Tue Jul 22, 2014 9:41 pm
if the piston was in the motor and it was already running, I would say just run it. But its out, you have the opportunity to change it easily, I would do so.
Re: Piston damage
Postby ___Scott___ » Wed Jul 23, 2014 3:19 am
Just my $0.02USD, but if it were mine I would just make sure the rings still move freely in their grooves and, assuming they do, I would put it back together and run it. I wouldn't lose any sleep over it either but maybe that's just me.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Re: Piston damage
Postby toddy2 » Wed Jul 23, 2014 6:57 am
Local shop says damage is a result of to much heat because of lean mixture. They have actually started to melt. So I think I will leave rvem and go for new ones.
Tanks for all the answers guys.
toddy2
