St185 with evo III turbo
Postby Mr Alltrac » Mon Jul 28, 2014 4:53 pm
I have the opportunity to get a tdo5-16g from an evo III rebuilt with 100 miles on it, no shaft play.
Would this be a worthwhile upgrade?
How does it compare to the ct26?
I plan to run 1 bar (14.7 lbs) of boost, so I don't think I will be putting a lot Of stress on the tdo5, what do you guys think.
Mr Alltrac
Re: St185 with evo III turbo
Postby gt4tified » Wed Jul 30, 2014 10:36 am
It's definitely a step up from the CT26, but then again, anything is. It can't touch a ct20b though.
gt4tified
Images: 5
Postby CTechBlueDragon » Wed Jul 30, 2014 3:58 pm
Well I was going to say you can probably put your wifes hair dryer in place of the ct26 and get a boost! But seriously its going to need a full custom setup oil lines and manifold or adapter and a special downpipe. For the gain you would get its cost prohibitive. CT20B is much easier and cheaper in the long run.
CTechBlueDragon
Images: 50
Postby Mr Alltrac » Wed Jul 30, 2014 9:26 pm
It comes with the o2 housing that I was gonna use and cut/ make a flange to bolt to my 3" exhaust pipe now. Make an adapter from the ct-t3 flanges. It's 100$ + work or 6-800$ for a ct20b that's the only difference. I guess I'll just hold out an build my motor and get a ko sb kit.
Mr Alltrac
Postby msanders2 » Wed Jul 30, 2014 9:31 pm
Gt3071r!!!!!!!! Do it. I'm going too, remember we gotta be twinsies.
msanders2
Postby Mr Alltrac » Wed Jul 30, 2014 9:45 pm
Debating, I was kinda wanting jus the gt28 cause I want fast spool and I'm only looking for 300whp.
Build me a stroker so we can match for sure haha.
Mr Alltrac
Postby msanders2 » Wed Jul 30, 2014 10:07 pm
I told ya brochacho come to Ga and we will swap that tranny and build you a stroker. Might take longer then a weekend though...
msanders2
Postby Mr Alltrac » Thu Jul 31, 2014 2:13 am
I'll drive up help you pull motor and leave you the car and I'll rerun to put it all back in haha.
Mr Alltrac
