ST185 (swapped st205) How much boost it takes?
Re: ST185 (swapped st205) How much boost it takes?
Postby Pipedreams » Thu Aug 14, 2014 4:49 pm
Yes, proper wiring makes a big difference. But on a st185 I used to have it wasn't enough to keep up with the demand of a ct20.
Pipedreams
Postby lordvampire » Thu Aug 14, 2014 5:15 pm
how much boost it kept up ? : )
lordvampire
Postby Pipedreams » Thu Aug 14, 2014 7:59 pm
I can't remember, it's ~7years ago :-) But I don't think I turned the boost until I had a new pump so it was less than 1bar but the pressure dropped at least 0,5bar in high revs so it was barely enough for 0,5bar of boost.
Pipedreams
Postby lordvampire » Fri Aug 15, 2014 5:16 am
I didnt know its so bad! I quess I turn the boost little down and order new fuel pump. : ) I want to keep the engine to wintertime also : )
lordvampire
Postby underscore » Fri Aug 15, 2014 5:39 am
0.5 BAR of boost? isn't that at/below stock?
Postby Pipedreams » Fri Aug 15, 2014 7:27 am
Yes it is. You just can´t expect a 20year old pump to be adequate for even a stock engine. But on the other hand I don´t remember if this was before or after I put in 550cc injectors and ran e85 which would increase the demand a hole lot.
Pipedreams
