a bad ct26 turbo?
a bad ct26 turbo?
Postby 91celicagt4 » Wed Oct 01, 2014 12:37 am
Long story short , bought my st185 off a local amigo (whom clearly ruined the whole car), when I first got the car , the car was smoking like shizzle(smokes all over the place coundnt even see the road while I'm driving, so I ended up tow it home).found out he bended the turbo oil return line(forced oil going back to turbo ).fixed that problem,took few ride let it idle no more smokes, but only boost 5psi at all gears , I can hear the turbo spool rpm moving but the car just going no where(also big clunk noise at rear end after breakboost) , so it means that turbo is done? This is my first turbo toyota, any help will be greatly appteciated!
91celicagt4
Re: a bad ct26 turbo?
Postby 91celicagt4 » Wed Oct 01, 2014 12:41 am
Also notice my speedometer is not moving :roll:
91celicagt4
Postby Anoo21 » Wed Oct 01, 2014 1:37 am
I can tell you the clunk is your rear diff mount just need to solid fill or buy a solid one from klue here on the site. Turbo wise i would have to let the other alltrac gods weigh in on it. Welcome to the alltrac world have had mine for 3 years finally getting to the bodywork but to me it is worth it owning a piece of history and i get a lot of respect from everyone who knows i own one.
Anoo21
Postby 91celicagt4 » Wed Oct 01, 2014 1:44 am
Thank u for ur help, I will definitely check that mount out .
91celicagt4
Postby 91celicagt4 » Thu Oct 02, 2014 4:15 pm
Any turbo guru here? I'm just trying to make sure be4 I replace the turbo !
91celicagt4
Postby UtahSleeper » Thu Oct 02, 2014 4:20 pm
Do you know if the car has boost controller on it? Seems really wierd to stop at 5 psi unless it is set to that. I assume the readings are coming from an aftermarket boost gauge.
UtahSleeper
Postby 91celicagt4 » Thu Oct 02, 2014 5:21 pm
Everything is stock except synapse bov(recir) and boost gauge.could it be a bad boost solenoid or tvsv?
91celicagt4
Postby underscore » Thu Oct 02, 2014 5:49 pm
Does the CEL come on at all, assuming it's working properly?
Postby 91celicagt4 » Thu Oct 02, 2014 5:52 pm
No cel (I dunno it's working or not ,but I do have abs and airbag light on the cluster :doh: )
91celicagt4
Postby 91celicagt4 » Thu Oct 02, 2014 5:56 pm
Currently rpm idles at 1000-1500......
91celicagt4
Postby underscore » Thu Oct 02, 2014 6:26 pm
Sounds like a possible boost/vacuum/exhaust leak
Postby 91celicagt4 » Thu Oct 02, 2014 6:57 pm
i do have a exhuast leak :shock: (it was cracked on before the flew section, former owner wrapped it with metal plate but still leaking,so i just cutted it to leave it open), this would limited my boost and cause my car to run like a jerk?? :doh: :doh: :shock:
91celicagt4
Postby underscore » Thu Oct 02, 2014 7:53 pm
As long as it's not before or too close after the O2 sensor you should be okay.
Postby 91celicagt4 » Mon Oct 06, 2014 11:02 pm
well.....still havent figure it out the issues,capped off the tvsv(still boost 5-6 psi at all gears didnt make any difference) :doh: but i do found a plug that isnt plugged,right under distributor. does anyone know what that is and where that goes to??
91celicagt4
Postby outinnowhere3193 » Wed Oct 08, 2014 5:59 pm
That plug I believe is a capped plug I think mine has the same one n goes nowhere. As far as turbo remove the air breather side of the turbo. You will see your compressor wheel. Grab the nut n give it a push pull. Should move little to none. Side to side is probably like a 1/16.. N by side to side I mean moving it back toward the rear and front of the car.
Obviously spins easily and a rebuild kit is on ebay for 60 bucks.
It's really simple to rebuild as well no special tools needed
outinnowhere3193
Images: 5
