throttle body buttery fly opening direction
Postby mixer72 » Mon Nov 03, 2014 10:14 am
just wondering does it make that much difference in witch way the butterfly opens? just as I see it the air can only go out of the valves that are open and all so even though the turbo is blowing air in to the engine the piston is still sucking the air in like and N/A does, so carnt see it would make that much difference, but would like people thoughts on this
mixer72
Re: throttle body buttery fly opening direction
Postby MWP » Sat Nov 08, 2014 1:57 am
Errrrr what :twisted:
Im sure your trying to ask a good question, but your sentence makes no sense at all. Did you write this drunk?
Postby mixer72 » Sat Nov 08, 2014 7:58 am
if you have a read of the same post I put up on this forum think you see what I mean
http://www.gt4dc.co.uk/forum/viewtopic.php?f=13&t=7209
mixer72
Postby anothergt4 » Sat Nov 08, 2014 8:47 am
Are you referring to the tvis?
anothergt4
Postby mixer72 » Sat Nov 08, 2014 9:28 am
no the throttle body butter fly as in the Subject
mixer72
Postby anothergt4 » Sat Nov 08, 2014 12:20 pm
Do our throttle bodies have the ability to go either way? I would assume one way or the other would increase velocity, but only because of the intake manifold.
anothergt4
Postby klue » Sat Nov 08, 2014 2:56 pm
Would it change anything at WOT, no. But at small throttle increments yes the air flow would be distributed differently into the plenum. Better or worse? It would have to be tested
Postby underscore » Sat Nov 08, 2014 6:36 pm
The stock setup is to have the bottom of the plate move towards the manifold and the top move away from the manifold, correct?
Postby mixer72 » Sat Nov 08, 2014 11:24 pm
underscore wrote:The stock setup is to have the bottom of the plate move towards the manifold and the top move away from the manifold, correct?
yes in a stock centre feed manifold it does, but on the caldina fide feed the butter fly opens the other way, so was wondering would it make any difference if a 205 throttle body was use as this opens plate move towards the manifold and the top move away
mixer72
Postby CTechBlueDragon » Sun Nov 09, 2014 1:13 am
I am interested in this too because I want to put a 205 TB on a 215 side feed manifold I didn't think about this being a factor.
CTechBlueDragon
Images: 51
Postby mixer72 » Sun Nov 09, 2014 9:09 am
I run a st162 side feed on my 185 so was all so wanted to know, would any 1 have a computer program that could work this out?
mixer72
Postby CTechBlueDragon » Sun Nov 09, 2014 1:37 pm
From what I can tell just by looking which is not much, it appears they just flipped the TB opening to make the throttle cable mount easier for the side-feed TB. I am not sure if other factors played in more or less.
CTechBlueDragon
Images: 51
