ST165 v ST185 Radiator
Postby freddie » Thu Nov 20, 2014 1:47 am
This may be a dumb question, but what is the difference between the radiator for a ST165 and a ST185
Is it the size? Or is it the supports/fixings? Or is it the location of the pipework?
What I am saying here is can I fit a ST185 radiator into a ST165?
freddie
Re: ST165 v ST185 Radiator
Postby Eurus » Thu Nov 20, 2014 6:28 am
freddie wrote:This may be a dumb question, but what is the difference between the radiator for a ST165 and a ST185
From what Ive read, the 185 is taller, and the water line from the turbo doesn't connect to it, but rather a separate line.
Eurus
Postby scottjackson1209 » Fri Nov 21, 2014 7:50 am
Same height, wider, no turbo coolant pipe, and top and bottom mounts are in different locations. I just put a mishimoto 185 radiator in my 165. Required some modification to fit. I had to move the mounts and cut Sime if the core support.
scottjackson1209
Postby klue » Sat Nov 22, 2014 3:12 pm
scottjackson1209 wrote:Same height, wider, no turbo coolant pipe, and top and bottom mounts are in different locations. I just put a mishimoto 185 radiator in my 165. Required some modification to fit. I had to move the mounts and cut Sime if the core support.
you can use the st185 rad just like scott is saying.
I had a customer send me the mishi st185 rad new in the box. I welded a port for the turbo line and sent it back to him. worked great
