W/A Heat Exchangers
W/A Heat Exchangers
Postby RedCelicaTRD » Fri Nov 21, 2014 1:13 am
What are my fellow ST185 owners using for heat exchangers? I assume most are running the stock units off a Mustang Cobra. Any other good options out there?
Re: W/A Heat Exchangers
Postby alltracman78 » Fri Nov 21, 2014 2:03 am
Fluidyne Cobra upgrade.
It's super thick though. Someday I'd like a thinner one with more face area.
Postby klue » Sat Nov 22, 2014 3:13 pm
brand name upgrades are on the money.
Next best is a custom quality core. air ducting is very important and overlooked.
Postby CMS-GT4 » Sat Nov 22, 2014 4:25 pm
Back in the day people used to pull radiators off Sub compacts to use as heat exchangers. I vote for custom or something like you find off a cobra.
Postby mx6er2587 » Sat Nov 22, 2014 8:41 pm
I'm using the LFP dual pass made as an upgrade for the Cobras. Fits great in the CS front bumper. Removes any sleeper effect a WTA system might normally have. Everyone just assumes its an ATA intercooler
mx6er2587
Postby HIRISK » Sun Nov 30, 2014 2:47 am
I did not realize the standard heat exchanger was a problem?
Are there good gains in cooling to be had with an upgraded heat exchanger?
HIRISK
Postby mx6er2587 » Mon Dec 15, 2014 5:07 pm
I don't believe the stock CS/RC heat exchanger is much of a problem. I went with the LFP because it was cheaper and easier for me to obtain than the factory parts.
mx6er2587
Postby athousandleaves » Thu Dec 18, 2014 4:25 am
Grab an aluminum racing radiator from a jetta or sirocco fits like a glove :smokes:
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby RedCelicaTRD » Thu Dec 18, 2014 4:42 am
Pictures of said VW setup?
Postby athousandleaves » Thu Dec 18, 2014 4:50 am
Car is in storage so you'll have to wait till the spring for pictures...
Just pull out a tape measure and compare to the measurements for the rads on eBay.
This is with an RC front setup mind you.
1992 White turbo4WD
athousandleaves
Postby milehigh_alltrac » Thu Dec 18, 2014 5:54 am
I am running this heat exchanger. Had to make custom brackets to mount in the front of my ST185 with CS front end.
https://www.frozenboost.com/water-to-ai ... f5b797ed9b
milehigh_alltrac
