Lo oil pressure
Lo oil pressure
Postby Robin-evo6rs2 » Wed Dec 03, 2014 7:45 pm
Hi,
I just put oil pressure gauge on my gen 2 3sgte..
Seeing pressure's off 25 psi max with 100 degrees temp. :shock:
When she is cold i got 85psi with a bit off rev's
And 25 @ idle..
Hot 20 @ idle and 25 max with revs....
What can i do?
Measured on a remote oil filter, which is in a oil cooler loop with a 80 degrees thermostat( all mocal)
Robin-evo6rs2
Re: Lo oil pressure
Postby scottjackson1209 » Thu Dec 04, 2014 5:27 am
That doesn't sound that bad to me...especially considering that it is being measured through a remote oil filter. Pressures would read higher in the head where the stock pressure gauge gets it signal from
scottjackson1209
Re: Lo oil pressure
Postby Robin-evo6rs2 » Thu Dec 04, 2014 5:56 am
Oke I will try switching the sensors around.
See what I have there.
Robin-evo6rs2
Re: Lo oil pressure
Postby klue » Fri Dec 05, 2014 2:10 am
thats actually pretty good oil pressure.
Re: Lo oil pressure
Postby scottjackson1209 » Fri Dec 05, 2014 2:33 am
That's what I was thinking
scottjackson1209
Re: Lo oil pressure
Postby Mafix » Fri Dec 05, 2014 12:25 pm
25psi idle is fine. 25psi at 3k rpm is BAD. which one are you saying you have?
Re: Lo oil pressure
Postby Robin-evo6rs2 » Fri Dec 05, 2014 1:47 pm
20 @ idle
25 @ 2500 and up
does not go higher than that when she is hot
Robin-evo6rs2
Re: Lo oil pressure
Postby scottjackson1209 » Fri Dec 05, 2014 1:51 pm
Did you measure from the head yet?
scottjackson1209
Re: Lo oil pressure
Postby Robin-evo6rs2 » Fri Dec 05, 2014 2:16 pm
No sorry. .
to busy with customers.
Tomorrow afternoon I will measure it.
Robin-evo6rs2
Re: Lo oil pressure
Postby klue » Sat Dec 06, 2014 2:50 pm
Ok also let us know what your viscosity is. Any bearing knock on start up?
Re: Lo oil pressure
Postby Robin-evo6rs2 » Sun Dec 07, 2014 10:34 am
Just switch'd over the sensors.
Going for a test drive this afternoon.
Cant hear eny bearings on start up.
I'm running 5w50 valvoline vr1 racing. .
Engine is in our Time Attact Corolla E11 8)
Full spec:
3sgte st185 Carlos sainz engine
Dtafast p8pro
Custom crank trigger wheel
Dis coil
Running speed density
FMIC
Stock turbo @ 1.3 bar
19 row mocal oil cooler with 80 degrees thermosat
323mm Wilwoods BBK
Custom BC Racing coil overs
Kaaz 1,5way LSD
When a got the oil pressure ill report back.
What should i expect to see in the head?
Cheers
Robin
Robin-evo6rs2
Re: Lo oil pressure
Postby Robin-evo6rs2 » Sun Dec 07, 2014 3:16 pm
I have 25 psi in the head :(
That's the psi I have from 2500rpm and up..
That's not good. ..
so what are my options?
Robin-evo6rs2
Re: Lo oil pressure
Postby klue » Sun Dec 07, 2014 4:54 pm
Seems weird.
I would pull a bearing cap to inspect for damages. If nothing is found replace the pump, it may be that the pressure relief is bad...
Re: Lo oil pressure
Postby Robin-evo6rs2 » Sun Dec 07, 2014 6:59 pm
Going to pull the engine tomorrow. ....
Robin-evo6rs2
Re: Lo oil pressure
Postby Mafix » Tue Dec 09, 2014 10:18 pm
wait a minute. is the engine dead vertical or on a lean? i wonder if you are having a starvation issue. put in an extra qt and see what happens.
