Lo oil pressure
Re: Lo oil pressure
Postby Robin-evo6rs2 » Wed Dec 10, 2014 5:01 am
Its on a small leen...
bottom of the sump in vertical.
For now I only took the sump off.
bearings look fine.
I got a 5s oil pump coming. .
going to try that to.
Robin-evo6rs2
Re: Lo oil pressure
Postby klue » Thu Dec 11, 2014 2:20 am
make sure to use the 3sgte oil pump gear, or you will have to change you belt
Re: Lo oil pressure
Postby Mafix » Fri Dec 19, 2014 6:23 pm
check the relief spring assembly in the old pump. i'd guess it has debris holding it open.
Re: Lo oil pressure
Postby Robin-evo6rs2 » Tue Dec 23, 2014 5:55 am
I ordered a belt from a 205..
Should come in today.
Hoop to have her up and running this evening :)
Going to pull the old pump apart to see if I can find something.
Robin-evo6rs2
Re: Lo oil pressure
Postby Robin-evo6rs2 » Tue Dec 30, 2014 5:11 pm
It have not worked as I hoped. .
got a 36 psi now at the most.
its @ 25 on idle... so that more then fine. ...
just as soon as I rev the engine its got 35/36psi @2k rpm.... that where it stays.
Bearings look fine.. so since of waer..
did not messuage them.
how to go from now?
Robin-evo6rs2
Re: Lo oil pressure
Postby MWP » Wed Dec 31, 2014 4:38 am
Mafix wrote:check the relief spring assembly in the old pump. i'd guess it has debris holding it open.
Did you check this?
I have heard of the oil relief valves getting stuck open.
BTW... are you sure your oil pressure gauge is accurate?
Re: Lo oil pressure
Postby Robin-evo6rs2 » Wed Dec 31, 2014 6:46 am
Im not using the relief valve eny more.
Same goes for the stock water/oil cooler.
Instead I have a sandwich plate with a 80 degrees thermosat going to a remote filter and 16 row cooler
yes . I trust the meter
Robin-evo6rs2
Re: Lo oil pressure
Postby Robin-evo6rs2 » Wed Dec 31, 2014 9:04 am
Could the thermostat throwing oil in the relief valve return when opening?
I mean when the oil is cold I have 95psi! On idle. ..
dropping to 75 psi after a 10min drive. ...
now I think the pressure drops when the thermostat opens???
How does the relief valve get rid of the excessive oil?
Could I blok that?
It must go wrong there...
Robin-evo6rs2
Re: Lo oil pressure
Postby Mafix » Wed Dec 31, 2014 3:38 pm
you don't seem to know what i'm talking about with the relief spring. it's in the oil pump, not the filter housing. it is what dictates the oil pressure.
Re: Lo oil pressure
Postby Robin-evo6rs2 » Wed Dec 31, 2014 5:35 pm
Its got a brand new 5s oil pump now.
Only done the test miles now.
And no.. I did now check the one in the new pump or the old one.
Robin-evo6rs2
Re: Lo oil pressure
Postby Robin-evo6rs2 » Thu Jan 01, 2015 7:02 pm
should i have opened up the new pump to check?
Robin-evo6rs2
Re: Lo oil pressure
Postby MWP » Sun Jan 04, 2015 10:01 am
Yup, its always a good idea to make sure it moves freely.
Re: Lo oil pressure
Postby Robin-evo6rs2 » Sun Jan 04, 2015 6:29 pm
I connected the line on the remote filter the wrong way arround :oops:
got 50 psi hot on idle and 75 with rev's :)
Robin-evo6rs2
Re: Lo oil pressure
Postby MWP » Mon Jan 05, 2015 2:36 am
Hot idle is 50psi?
Is that measured at the head?
Re: Lo oil pressure
Postby Robin-evo6rs2 » Mon Jan 05, 2015 5:37 pm
40psi on the stock oil pressure sensor location.
Idle.. with 80 degrees oil temp.
Robin-evo6rs2
