smaller turbine (exhaust) housing
Postby st185-sainz » Sun Aug 22, 2004 3:54 pm
guys,
I have some CT26 turbos at home and noticed that I have two different exhaust housings and wheels. One is larger and the other one is smaller!
Are there any other housings I can use which are small due to my small one is cracked? I read that there is one for the ST165 from Turbonetics but is there anyone out for ST185 too?
thanks in advance
mario
Mario,
ST205 blue: completely stock
ST185CS (white): white - gravel/snow spec, dog box, TRD clutch, uprated turbo, lightened flywheel, uprated actuator, cold air intake, ST182 cams, walbro pump, batt relocation, forgies, programmable ECU (dyno), ...
st185-sainz
Postby pog0 » Sun Aug 22, 2004 6:59 pm
Mario,
It seems as if you have a single entry CT26 from a Supra (the bigger one with a 4 bolt discharge flange) and a dual entry CT26 from the 2nd gen 3SGTE (6 bolt discharge).
I dont think there is a replacement turbine housing for the 185 similar to the one turbonetics sells for the 165.
Kevin Hall
92 Gray ST185 - Sold
01 GGP IS300 - Sold
06 GG Evo IX MR
San Diego
pog0
Postby st185-sainz » Sun Aug 22, 2004 7:13 pm
both have the same flange and are twin entry! I talked about that to my turbo specialist and showed him the housings and he said that they are different!
As I wrote, one is smaller. But both are twin entry and have the same flange and bolt pattern!
Mario,
st185-sainz
Postby alltracman78 » Sun Aug 22, 2004 9:29 pm
Pic?
Postby RedCelicaTRD » Mon Aug 23, 2004 12:09 am
The smaller one is probably a ct20b. they had a smaller turbine and a smaller compressor also.
Postby st185-sainz » Mon Aug 23, 2004 2:19 am
is there an other garret housing or so that I can use which is smaller?
I'm not really sure if the upgraded ones als use different exhaust housings?!
thanks
Mario,
st185-sainz
Postby OlyST185 » Mon Aug 23, 2004 3:33 am
hmm it is not the CT26 that is smaller than the CT20b?
the CT20b is a much more better turbo
-Oly (Montreal)
3SGTE'S POWER, 4WD SUPREMACY
[img]http://olyst185.multimania.com/turbo4wd.jpg[/img]
-ST185 1990 Black. RC/CS Conv.
OlyST185
