ST215 blow off valve Q
Postby UtahSleeper » Thu Dec 18, 2014 7:29 pm
So, I just installed a a 4th gen 3sgte and have a question. I found this pic:
And it looks like there a BOV located right before the TB. Is this a needed thing or can I just recycle it into the intake?
Sorry if its a noob Q, but just trying to iron out details before making my intake.
UtahSleeper
Re: ST215 blow off valve Q
Postby DeeCee » Thu Dec 18, 2014 7:52 pm
ST215 does not have a bov as stock from what I remember. The picture shows an aftermarket bov added before the TB.
If you do use a bov, you can plumb it back into the intake or run it open and make loud noises. Recirculation of the BOV air will not give you a phsss on throttle release - and all the old people will thank you for it ;)
DeeCee
Postby UtahSleeper » Thu Dec 18, 2014 7:59 pm
DeeCee wrote:ST215 does not have a bov as stock from what I remember. The picture shows an aftermarket bov added before the TB.
I mostly wanted to verify that I did not need a BOV for the motor. So, I should be able to just cap it and not worry about it then?
UtahSleeper
Postby DeeCee » Thu Dec 18, 2014 8:05 pm
My bad. There is a stock bov located on the factory airbox, therefore it is already recirculated into the air intake system. You are best to keep it if you are expecting to run a stock factory setup.
DeeCee
Postby UtahSleeper » Thu Dec 18, 2014 8:10 pm
Thank you!!!!
Had no clue. Now I know what to get next.
UtahSleeper
