Heat Barriers
Heat Barriers
Postby ViciousDelta » Fri Feb 20, 2015 12:16 am
I see quite a few Tracs on here that are using different kinds of heat wraps on the stock IC and intake pipings ect. Some are silver and some are gold. I have some regualr exhaust wrap im about to put on my Downpipe but im interested in wrapping my intercooler with some of this foil looking stuff. anyone know what it is and where to get it?
1988 AllTrac, 1st Gen 3S-GTE
1991 Celica GT Liftback JDM 3S-FE
1979 SR5 Corolla Liftback, 2-TC
1968 Mustang GT Coupe w/ 351 Cobra Jet
ViciousDelta
Re: Heat Barriers
Postby celica_gtx » Fri Feb 20, 2015 4:19 am
http://www.frsport.com/Heat-Defense-Hea ... fgodF5cAaQ
You can also get it on eBay, summit ect.
What IC are u using?
transformation has BEGUN!!!
90GT W/ 90 3SGTE/ SOLD
91 ALL-TRAC 215 w 205 swapd
10 Scion Xb-kid hauler
celica_gtx
Re: Heat Barriers
Postby ViciousDelta » Fri Feb 20, 2015 5:57 am
Just the stock 165 IC. Thinking about hunting down a bigger heat exchanger for it. I live in Montana and its not very friendly to front mounts up here. Gonna have to research the forum to see if anyone got themselves a bigger heat exchanger on their 165
ViciousDelta
Re: Heat Barriers
Postby athousandleaves » Sat Feb 21, 2015 4:39 am
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Re: Heat Barriers
Postby ___Scott___ » Sat Feb 21, 2015 2:56 pm
I'm not sure how this stuff differs from the Thermotec stuff referenced in the link above, but it always seemed like it would work well to wrap an intercooler:
http://www.homedepot.com/p/UltraTouch-4 ... /100656748
It's a lot cheaper than the Thermotec stuff, but but it seems like I paid a lot less when I bought some to wrap a water heater about 10 years ago.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Re: Heat Barriers
Postby athousandleaves » Sun Feb 22, 2015 7:08 pm
I have a feeling that home depot blanket isn't designed to withstand exposure to excessively high temperatures as it's a blend of natural fibers that have been treated to resist burning with a fire retardant, unlike the synthetic fibers in the thermotec product that are designed for up to 2000°F.
It's nice how thermotec actually tells you the percent it's able to REFLECT/BLOCK and the heat range it's able to withstand under contact or radiantly unlike other high temp stuff on the market.
For example the Mishimoto tape posted earlier... that's great that it can withstand up to 675°F of radiant heat but how much of that heat will it actually reflect? Or you could look at the countless spray cans of high temp paint that people use thinking it actually helps reduce temperatures under the hood :crazy:
1992 White turbo4WD
athousandleaves
Re: Heat Barriers
Postby ___Scott___ » Sun Feb 22, 2015 9:17 pm
I would suggest that if your under-hood temps are so high that the Home Depot stuff can't handle it, then you are working on the wrong problem.
If applied in a "not too tight" manner and sealed up tight to keep it from absorbing moisture, it should work well. Even if it doesn't last forever, at least it was cheap enough (and you probably have plenty left over) to do it again.
Regarding insulating paint. Yeah, most of it is junk. Actual insulating paint does exist though, check out the stuff here:
http://www.hytechsales.com/
Scott
SONY
___Scott___
Re: Heat Barriers
Postby Hotrodhendrix » Fri Mar 06, 2015 4:57 pm
I used to use the home depot self adhesive reflective roll with insulator on the charge pipe. Seemed to work fine but got rid of it of it when I powdercoated it. Never took any readings to see the difference.
~James
