Replacing fuel line
Replacing fuel line
Postby Hotrodhendrix » Thu Apr 09, 2015 3:46 pm
My feed line is boogered up under the stock filter and towards the tank so the plan is to replace with 6an SS line. My question is does any know which connectors I will need for the stock fuel filter and fuel pump assembly? Now the stock fuel pump assembly connector will have to be cut off and a new one installed so that part is flexible if needed.
Thanks for the help!
~James
Re: Replacing fuel line
Postby athousandleaves » Thu Apr 09, 2015 8:18 pm
Fuel line is M14x1.5 at both ends. :smokes:
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby yyonline » Fri Apr 10, 2015 5:15 am
I just picked up a new fuel filter at the dealer today, so I can confirm that it is M14x1.5 on the fuel filter end at least.
yyonline
Postby Hotrodhendrix » Fri Apr 10, 2015 9:10 pm
Thanks guys!
~James
