My feed line is boogered up under the stock filter and towards the tank so the plan is to replace with 6an SS line. My question is does any know which connectors I will need for the stock fuel filter and fuel pump assembly? Now the stock fuel pump assembly connector will have to be cut off and a new one installed so that part is flexible if needed.
Thanks for the help!
~James
~James
