Ignition Coils?
Ignition Coils?
Postby Eurus » Tue May 05, 2015 10:12 am
Im thinking of replacing my Ignition Coil here shortly, but would rather upgrade, than just go OEM.
However I dont know a lot about them, so I dont know what would be usable on a st165.
Thanks in advance.
Eurus
Re: Ignition Coils?
Postby Pipedreams » Fri May 08, 2015 5:33 pm
No real gains to be made so just keep it stock and spend your money on new rotor cap and leads instead, They are fine even at 500+hp
Pipedreams
Re: Ignition Coils?
Postby NoMan » Mon Jan 04, 2016 12:47 am
I went with VAG coil on plugs :) Have not mounted them yet though.
Well, oem works, but if you go standalone ECU then you cant do much with the oem dizzy. And you do get better spark with coils :) But for oem ecu i would stay with the dizzy, less hassle to get it to work :)
NoMan
