Anyone RECENTLY Buy A Complete Ebay Exhaust?
Postby alltracman78 » Tue May 19, 2015 1:47 am
I needed one for a quick cheap fix, so I ordered this one. $290 shipped is too cheap to pass up.
http://www.ebay.com/itm/190627860043
It doesn't quite fit. It's very close. It's rammed up against the front crossmember on the rear subframe, rammed up against the transfer case [both those I made work] but it's also rammed into the front crossmember to the extent I can't install the crossmember [more than what a hammer will quickly fix].
Yes I know it's cheap ebay. I understand all that. I'm debating whether to keep it and try to reweld it or if it's worth it to try to return it for one that MIGHT fit, it's going to be a while before I'll be able to get around to reworking this.
I was wondering if anyone has received one that they were able to make work on the car? If so from what seller? I'm wondering if these are all comeing from the same factory/jig or if different people are making them. They look the same in the pictures [if you do an ebay search for ST185 exhaust].
Re: Anyone RECENTLY Buy A Complete Ebay Exhaust?
Postby 013 » Tue May 19, 2015 5:45 am
I think I have heard that the OBX ones are better. I don't know from experience though.
http://www.ebay.com/itm/OBX-Cat-back-Ex ... 0043&rt=nc
How can we check to see if ebay sellers' products are authentic before buying them?
013
Postby alltracman78 » Tue May 19, 2015 11:53 am
That looks exactly the same as the one I got.
Which doesn't mean it is. A few small tweaks and the one I have will fit just fine.
Only way to really tell is talk to someone that has ordered one.
Or if you can get the seller to confirm in a message, then when you get it and it isn't you should have a good case for returning it.
Which by the way it the reason I pay with a credit card; much less hassle to get your money back.
Anyone else?
Postby CMS-GT4 » Tue May 19, 2015 12:47 pm
Drew Monk ordered one. I think he had to have the midpipe bent to fit just right but the cat back was another brand. Crossmember figment with 3" midpipe has always been a problem. People either dent them or add spacers.
Postby alltracman78 » Tue May 19, 2015 1:20 pm
Yeah, up til now the problem was just rattling though [at least for me].
I'll have to actually cut a chunk out of the crossmember to fit this unless I cut/weld it.
Postby celi703 » Tue May 19, 2015 5:43 pm
I ordered this for my alltrac and it was a pain to install. It fits but is a tight fit. I recommend starting with the back portion. After that it should all fit in place.
90 ST185 3E5
14 FB6 TW
celi703
Postby alltracman78 » Tue May 19, 2015 9:39 pm
So the one you got from the exact same seller fit?
Mine doesn't. It's all in the car but I have to cut the front suspension crossmember to be able to install it.
Postby sammyw » Tue May 19, 2015 9:59 pm
Ohhhh goood lord! This looks exactly like the one I got on Amazon. Biggest issue is that it is bigger than 2.5", more like 3". So many issues getting it to fit. Haven't got it quite right yet but the rattling is only really bad at 3000 rpm.
The thing is, I asked about it on here and a couple people had bought it and they said nothing about the fit. Maybe it was a different seller...
The exhaust has been the bane of my existence the last few months :shoots:
sammyw
Images: 6
Postby alltracman78 » Tue May 19, 2015 11:05 pm
It's a 3" exhaust. The tips are 2 1/2 inches.
So it seems like these aren't all exactly the same.
Postby TheNubkins » Wed May 20, 2015 2:58 am
My advice, don't cut the cross-member to fit an exhaust pipe. Dent the exhaust pipe where it is interfering to gain clearance. It's just a pipe carrying exhaust to the back of your car and is really not that important; and you will see pretty much zero power loss for the tiny dent you may need to put into it, and eventually the exhaust will corrode and need replacing anways. The cross member, should, last the lifetime of the vehicle barring any accidents. Again just my two cents, but remember these cars are rare, and one day parts will become even more scarce than they already are. Anyone can make exhaust to replace what wears out, but special car components are a different story.
The Nubkins
-2001 VW Golf TDI
TheNubkins
Postby UtahSleeper » Wed May 20, 2015 3:17 am
http://www.ebay.com/itm/2-5-DUAL-TIP-STAINLESS-EXHAUST-CATBACK-SYSTEM-FOR-89-93-CELICA-ST185-2-0L-TURBO-/151684961610?hash=item235120d54a
I bought this for my 165 and it fit snug, but seems to fit well. Looks exactly like yours..........but who knows if there are little differences
UtahSleeper
Postby alltracman78 » Wed May 20, 2015 11:21 pm
I appreciate the advice, but I had no intentions of cutting my crossmember. :P
I was just stating that's the only way it will fit [other than denting the pipe].
I have dented a 3" exhaust previously so I could use the Cusco lower brace. I never dynoed it but the boost did come up noticeably quicker. It required close to what this will. I'd guess it makes the exhaust ~ 2 1/2 inches at that point.
Postby yyonline » Thu May 21, 2015 6:51 am
alltracman78 wrote:I was just stating that's the only way it will fit [other than denting the pipe].
I don't have that particular exhaust...but my exhaust does have some clearance issues with the front cross member. THe previous owner cut a chunk out of the cross member, and I didn't particularly like that solution. So, I bought a used cross member and shimmed it up with some washers and longer bolts. No more exhaust rattle. The bolts I used were Volkswagen P/N WHT003467 and are 70mm long vs. 54mm for the stock bolts. They're M14x1.5 so it's an odd size and I didn't have much luck finding them in hardware stores in the right length. Plus the VW bolts are hardened steel and plated to resist rust.
yyonline
Postby CMS-GT4 » Fri May 22, 2015 12:31 am
How has everyone been satisfied with the sound and performance of the exhaust.
Postby alltracman78 » Fri May 22, 2015 12:50 am
Sounds good at idle. That's as far as I've gotten.
yyonline wrote:I don't have that particular exhaust...but my exhaust does have some clearance issues with the front cross member. THe previous owner cut a chunk out of the cross member, and I didn't particularly like that solution. So, I bought a used cross member and shimmed it up with some washers and longer bolts. No more exhaust rattle. The bolts I used were Volkswagen P/N WHT003467 and are 70mm long vs. 54mm for the stock bolts. They're M14x1.5 so it's an odd size and I didn't have much luck finding them in hardware stores in the right length. Plus the VW bolts are hardened steel and plated to resist rust.
That's good info. I thought about lowering [shimming] the member, but the stock bolts are way too short.
Thanks.
