st185 swap
st185 swap
Postby texturboII » Tue Jun 23, 2015 6:36 pm
For the life of me, I cannot find information on the st185 into a st165 swap. From what I've gleaned: mechanically it's straightforward but the hiccup comes in getting the wiring done. 3 hours of searching and that's all I've got. No links to schematics or directions, just threads upon threads of "Oh it's pretty easy, it drops right in, really popular swap" and one dead-end link to GTfour.ca that no longer has the information available that everyone pointed to from 2005. Ten years later I can't find squat on the specifics of the swap!
Can someone please point me in the right direction?
Judging from the lack of st185 front clips available it looks like running an aftermarket igniton and fuel setup may be the best of options...
texturboII
Re: st185 swap
Postby zaluss » Tue Jun 23, 2015 6:46 pm
texturboII wrote:For the life of me, I cannot find information on the st185 into a st165 swap. From what I've gleaned: mechanically it's straightforward but the hiccup comes in getting the wiring done. 3 hours of searching and that's all I've got. No links to schematics or directions, just threads upon threads of "Oh it's pretty easy, it drops right in, really popular swap" and one dead-end link to GTfour.ca that no longer has the information available that everyone pointed to from 2005. Ten years later I can't find squat on the specifics of the swap!
I just dropped a ST205 into my ST165. Based on what I've read, you would do the same things I did to "bolt" the motor into the car. Swap over your ST165 pass and trans motor mounts over to the ST185. Swap the brackets from the ST165 for the N/S torque mounts. Your propeller shaft will slide right into the existing transmission.
I would go with the ST205/ST215 personally unless you have a ST185 motor handy.
zaluss
Re: st185 swap
Postby texturboII » Tue Jun 23, 2015 6:56 pm
Thanks for the reply!
Yea, we've got access to a ST185, and knowing a bit about MegaSquirts there's a lovely plug and play standalone for the ST185 that they make.
Did you just swap over all of the electrical components as well? Any modifications for the fuse box or anything?
Looks like we're going to have to just fab up a whole harness and fuse box from scratch? Exciting...
texturboII
Re: st185 swap
Postby texturboII » Tue Jun 23, 2015 7:04 pm
texturboII
Re: st185 swap
Postby zaluss » Tue Jun 23, 2015 8:28 pm
texturboII wrote:FOUND IT!!!!
http://www.celicatech.com/forums/showthread.php?40738-How-To-Re-Wire-Your-Swap&p=30010153#post30010153
For future references... sorry for the clutter all.
I would never attempt to do such a crazy thing. I had wiregap do my wiring, which combined the ST205 with the ST165 fuse box.
zaluss
