the mr2oc board has a parts list of what is needed
kblake thank you another detail i was looking for: 5sfe flywheel bolts. these are the tips and tricks im looking for.
ok so the list for the 2.2 stroker in a 3sgte block should be:
1. 5sfe crank (machined to accept 3s rods)
2. 3sgte rods ( stock w/arp rod bolts, eagles, crower or pauter).
3. 5sfe main seal
4. stroker pistons (either cp, wiseco or modified standard 3sgte pistons)
5. fidanza or st165 flywheel (or modified 3sgte flywheel w/ elongated holes)
6. 5sfe flywheel bolts
everything else is 3sgte? any concerns with the bearings? any other details to consider for this short block assembly????
-all considered when you calculate in the machine shop costs...it seems alot better to just buy one already built.
but info like this is good so that theres an understanding of whats involved and for those who can build one on their own. any more details, tips and tricks welcomed
