Will this MR2 turbo kit fit on my ST185
Postby EvanP246 » Tue Aug 11, 2015 11:20 am
Hi everyone,
I'm looking to purchase this turbo kit:
It was on an MR2 previously. Does anyone know if this will fit on a GT-Four without any major mods?
Thanks,
Evan
EvanP246
Re: Will this MR2 turbo kit fit on my ST185
Postby Sifu » Tue Aug 11, 2015 4:26 pm
The kit will fit our motors obviously but its the clearance that causes most header issues. Either the exhaust header is too close to the radiator (vs the MR2 firewall) or the header (intake or exhaust) wont clear the hood or firewall. Get measurements. If its a kit from an MR2 service provider then maybe you can call and ask otherwise get measurements and base those compared to stock measurements.
Just by looking at it I think it will clear both the rad and hood.
BROKEN! BUT NOT BEATEN!
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby Spectra1 » Wed Aug 12, 2015 12:55 am
I have that same manifold with a gt35r turbo. It clears everything except the number one cylinder runner needs to be cut out and re angled to clear the alternator.
93 St185 DD
90 ST185 - Project
Spectra1
Postby Spectra1 » Wed Aug 12, 2015 1:00 am
Also the down pipe clearance with the ac pump was to close for attachment of the lines. Im not sure if that screamer pipe will fit as mine was one long flex section. These kits were made by a company called extreme boost if I remember correctly. They are decent quality but the manufacturer had really bad buisness skills and went under.
93 St185 DD
90 ST185 - Project
Spectra1
Postby Spectra1 » Wed Aug 12, 2015 1:04 am
viewtopic.php?f=44&t=49881
You can see a pic of the manifold installed in my build thread
93 St185 DD
90 ST185 - Project
Spectra1
Postby EvanP246 » Wed Aug 12, 2015 1:37 am
Thank you so much man. I'm gonna go for it!
EvanP246
